Hi guys. Some days ago saw this code from the forum.
I simulated it on Proteus and I was able to graph some oscillators like Lorenz, Rossler and Chua but I couldn't graph systems with 4 state equiations. I'm new in Arduino so i will really appreciate your comments
Thank you in advance.
float x_pos;
float y_pos;
int x_out = 5;
int y_out = 6;
float x = 0.1;
float y = 0.1;
float z = 0.1;
float w = 0.1;
float a = 3;
float b = 22;
float c = 8.1;
float d = 4.1;
float xdot;
float ydot;
float zdot;
float wdot;
float dt = 0.01;
pinMode(x_out, OUTPUT);
pinMode(y_out, OUTPUT);
// this next section changes the PWM frequency - don't mess with it!
TCCR0A = ( 1<<COM0A1 | 0<<COM0A0 | // clear OC0A on compare match (hi-lo PWM)
1<<COM0B1 | 0<<COM0B0 | // clear OC0B on compare match (hi-lo PWM)
1<<WGM01 | 1<<WGM00); // set PWM lines at 0xFF
TCCR0B = ( 0<<FOC0A | 0<<FOC0B | // no force compare match
0<<WGM02 | // set PWM lines at 0xFF
0<<CS02 | 0<<CS01 | // use system clock (no divider)
1<<CS00 );
TIMSK0 = ( 0<<OCIE0B | 0<<TOIE0 |
0<<OCIE0A );
xdot = a*x-y*z;
ydot = -b*y+x*z-z*w;
zdot = -c*z+x*y;
wdot = d*(y-w);
x = x + (xdot * dt);
y = y + (ydot * dt);
z = z + (zdot * dt);
w = w + (wdot * dt);
x_pos = 128+(50 * x);
y_pos = 128+(50 * y);
analogWrite(x_out, x_pos);
analogWrite(y_out, y_pos);
