Hello,
I want in a tft screen have some input from a a touchscreen to have 3 inputs (0 to 9). This code is working, but i get some strange results…
I make another test sketch to test this. Here i have the same results…
Can anyone tell me what I’m doing wrong
Thanks
String cText = "xxx";
Serial.println(cText);
delay(2000);
void loop(){
cText = "___";
while (int i = String(cText).indexOf('_') != -1){
// wait for some input, but this is working, now I changed it in i
i= i+1;
if(i = 1){
cText[0] = "1";
Serial.println (cText);
if(i = 2){
cText[1] = "2";
if(i = 3){
cText[2] = "3";
// teller();
void teller(){
String nameString = "Jacques Verleijen";
for (int counter = 0; counter <= nameString.length() - 1; counter++){
Serial.println(nameString[counter]);
Found the problem myself. Using single quotes in stead of double quotes solved the problem. I'm new in C programming (used to use Delphi). Can anyone tell me de diferrence between
String a= "1" and String a= '1' ?
Thanks
. Can anyone tell me de diferrence between String a= "1" and String a= '1' ?
Well whatever is in between double quotes is a String or char*/ char-array, what is between single quotes is a 'char'. The difference between the 2 statements you posted seems irrelevant, because i'd say that the 'char' gets cast to a String, and then assigned.
