Char array convert to uint8_T
I need to input text from the serial monitor in the char array form and pass it a uint8_t. A custom library then sends the uint8_t array to another arduino. The program is not converting the char array to uint8_t as I would expect. can you see any obvious issues.
#include <Manchester.h>
#define TX_PIN 5  //pin where your transmitter is connected
#define LED_PIN 13 //pin for blinking LED
const byte numChars = 32;
uint8_t message[numChars]= {'\0'};
char receivedChars[numChars];
boolean newData = false;
uint8_t moo = 1;
  Serial.begin(1200);
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, moo);
  Serial.println("Enter a Message:");
  man.setupTransmit(TX_PIN, MAN_1200);
  //recvWithEndMarker();
  //showNewData();
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
    while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (rc != endMarker) {
      receivedChars[ndx] = rc;
      ndx++;
      if (ndx >= numChars) {
        ndx = numChars - 1;
    else {
      receivedChars[ndx] = '\0'; // terminate the string
      ndx = 0;
      newData = true;
  if (newData == true) {
    Serial.print("This just in ... ");
    Serial.println(receivedChars);
    message[numChars] = receivedChars[numChars];
    man.transmitArray(numChars, message);
    moo = ++moo % 2;
    newData = false;
bfranman:
Where in the program did you expect to make that conversion?
Since uint8_t and char are the same size, just lie to the compiler and cast the char array to an array of uint8_t. It will never know the difference. What comes out the other end of the line would be the same either way.
Were you hoping to copy the entire array with that statement? It doesn't even copy a char that belongs to the string you're interested in.
this isn’t performing what the OP thinks is happening:
that is copying an undefined element out of the range of recievedChars to an undefined element of message.
arrays of size = numChars have a total of numChars elements numbered zero to numChars - 1
take Delta_G’s advice and use a loop to cast/copy the array:
for (int i = 0; i < numChars; i++)
  message[i] = uint8_t(recievedChars[i]);
No loop, just cast the whole thing when you pass it to whatever function is expecting an array of uint8_t.
 someFunctionExpectsByteArray((uint8_t*) someCharArray);
or
memcpy(message, receivedChars, numChars);
