char array questions [solved]
Question1: If you have some variables like:
byte keys = 7;
char myString[10] = "-3.141";
What is the preferred way to add the value of "keys" at the end of "myString", so that "myString" becomes (in this case) "-3.1417" ?
Question2: Is there a command that will assign a new string to a char array ? When using String class there is the assignment operator but how do you do it with a char array ? Do I need to assign every element individually one by one ?
Question3: Is there a command to add/remove the first or last char in an char array ?
Take a look at strcat strcpy and strlen.
...and remember that you need to convert keys to ASCII
int len = strlen(myString);
if (len < 9) {
    myString[len++] = keys + '0';  // Convert one digit (0-9) to ASCII
    myString[len] = '\0';  // NULL terminator
How is strcpy supposed to work ? If I have
char myString[10] = "seven";
strcpy(myString, "two");
Do I get "two" or "twoen", in other words does it take care of the nul termination sign at the end ?
When I use
strcat("-", myString);
I get
warning: deprecated conversion from string to "char*" [-Write-strings]
Why do I get this warning ?
just read about strcpy()
cinnamonBunny:
How is strcpy supposed to work? If I have
You get "two". It copies the null terminator along with the string.
cinnamonBunny:
When I use
I get
You are trying to copy an array of characters into a string constant. This will likely cause a crash, especially if your character array contains a string of more than one character.
In general you should be using "strncpy(destination, source, destination size)".
strncpy(myString, "two", 10);
If you don't, then someone could enter a string larger than you expect and cause memory corruption. This is a common way that programs develop security vulnerabilities.
Many of the string processing functions involve a "source" of the data and a "destination" where to put the data. So something like strcpy() has:
  • strcpy(destination, source);*
In every case, destination must be a char array which acts like bucket into which you pour the characters that are being held in source. Your code:
  • strcat("-", myString);*
is trying to dump the characters in myString[] into a destination that is a single character. That will never work since there's really no place to put the characters.
It would have taken less time to try it and see than to post this question.
Thank you for the people who tried to help.
