Char array/String to int conversion
Hello. I'm working on this code:
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean newData = false;
    Serial.println("<Arduino is ready>");
    recvWithEndMarker();
    showNewData();
void recvWithEndMarker() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (rc != endMarker) {
            receivedChars[ndx] = rc;
            ndx++;
            if (ndx >= numChars) {
                ndx = numChars - 1;
        else {
            receivedChars[ndx] = '\0'; // terminate the string
            ndx = 0;
            newData = true;
void showNewData() {
  String num = String(receivedChars);
  long numeretto = num.toInt;
    if (newData == true) {
        Serial.print("This just in ... ");
        Serial.println(receivedChars);
        newData = false;
What I want is to get a number in the Serial monitor and turn on and off a led N times (n = monitor input).
The monitor can only send chars, that I save into received chars. In the showNewData function I tried to convert it to a string and then to an int, but I get this error:
cannot convert 'String::toInt' from type 'long int (String::)() const' to type 'long int'
What do I have to do? Thanks
Not:
But:
  long numeretto = num.toInt();
Assume that you have sent 12 from the InputBox of the Serial Monitor with Newline option active. In the UNO, receive the incoming data bytes by executing the following instruction:
Serial.readBytesUntil('\n', myData, 20);
where, received bytes will be saved in a null-byte terminated character type array named myData[]. After that, apply the following code to get 12 back.
int x = atoi(myData);
Full Codes:
char myData[20] = "";
   byte x = Serial.available();
   if(x !=0)
       int y = atoi(myData);
