char array to binary and then to digitalWrite
Hello,
I would like to do this:
I have a char array, say:
char *myarray = "ciao"
I want to iterate over each char, convert it to binary and use this binary code to DigitalWrite(HIGH or LOW) a particular pin.
Each bit is a HIGH or a LOW
I think that the proper code would use binary shifting and should be simple.. I ask for someone more expert than me on the topic.
A code example would be appreciated
Thank you,
robse
Clarification please
Exactly what would the digital output be for 'c' ?
They already are binary.
No conversion necessary
[u]bitRead()[/u] will read one bit at a time so you can read a bit and then write it with digitalWrite().
Sometimes this is called "bit banging".
And of course, you can read/write one array element (one character) at time.
And, you might want to "print out" the binary values for testing/debugging.
For example, [u]ASCII[/u] 'c' is 99 (decimal) = 63 (hex) = 01100011 (binary)
This is the coded I needed, thank you
char *inputline = "ciao";
int d,w;
for(d=0;d<strlen(inputline); d++) {
  for(w=0; w<8; w++) {
      Serial.print(bitRead(inputline[d], w));
//    digitalWrite(10, bitRead(inputline[d], w));
