char array via i2c send and receive
Hi
i am trying to figure out how can establish i2c connection between one master and one slave arduino and send an char Array
my problem so far is that i cant read the sending array to my slave device
here is the code for both of them
Master:
#include <Wire.h>
byte call_02 = 12;  // pin for reading button
byte call_01 = 11;  // pin for reading button
char buttonArray[8] = {'a', 'r', 'd', 'u', 'i', 'n', 'o', '\0'};
// char Str2[8] = {'a', 'r', 'd', 'u', 'i', 'n', 'o'};  // it is the sama as above
// char Str5[8] = "arduino"; // it is the sama as above
//const byte button0_Floor = 11;
//const byte button1_Floor = 12;
  Wire.begin();
  pinMode(call_01, INPUT_PULLUP);
  pinMode(call_02, INPUT_PULLUP);
  int button0_FloorState = digitalRead(call_01);
  int button1_FloorState = digitalRead(call_02);
  if (button0_FloorState == LOW) {
    buttonArray[2] = 'W' ;
  if (button1_FloorState == LOW) {
    buttonArray[4] = 'Q' ;
  Serial.println(buttonArray);
  Serial.println(buttonArray[2]);
  Wire.beginTransmission(4);  // transmite  to slave with address 4
  Wire.write(buttonArray, 8);   // sends array  with the name buttonArray
Slave :
#include <Wire.h>
const byte slaveAddress1 = 4;
boolean flagButton = false;
char buf[8];
  Wire.begin(slaveAddress1);         // join the I2C bus as slave
  Wire.onRequest(requestEvent);     // Register a function to be called when a master requests data from this slave device
  Wire.onReceive(receiveEvent);
  Serial.println(buf[2]);
  Serial.println(buf);
  Serial.println("test");
void requestEvent() {
  if (flagButton == false) {
    Wire.write(' ');
    Serial.println("no call");
void receiveEvent(int howMany)
  while  (Wire.available())
    buf[8] = Wire.read();
the goal of these code is just to understand how "array" (send/receive) works in order to use it as function in a bigger project i have in my mind were i am using "Wire.write" function for each button state separately
Thanks in advance
On the slave, there is no element at position 8. You are crapping on memory you don't own.
You need a variable as an index into the array, incremented each time you are to the array.
Your read method is wrong, you are reading all bytes to the last byte of the array:
byte index = 0;
while  (Wire.available() && (index < 8)) //Make sure that only a max of 8 bytes are read
  buf[index++] = Wire.read(); //Read one byte to index and increment (++) index
Check again. OP is writing all bytes PAST the end of the array.
@OP
PaulS:
PaulS:
Based on the above mentioned observations, I have moderated/tested your codes (UNO+NANO) which are given below. Please, check/compare these codes with your original codes and note down the mistakes you have done.
Master Codes:
#include <Wire.h>
  Wire.begin();
  /* temporary suspension
  Serial.println(buttonArray); //arduino
  Serial.println(buttonArray[2]); //d
  Serial.println("=====================");
  //delay(500);
  Wire.write(buttonArray, sizeof(buttonArray));//8);   // sends array  with the name buttonArray
  Wire.endTransmission();
  delay(2000);
Slave Codes
bool flag1 = LOW;
#include <Wire.h>
char buf[8] = ""; //;
  if (flag1 == HIGH)
    Serial.println(buf);  //arduino
    Serial.println(buf[2]);  //d
    Serial.println("=================");
    flag1 = LOW;
  // delay(500);
  //  Serial.println("test");
void requestEvent()
    Wire.write(' ');
  // while  (Wire.available())
  for (int i = 0; i < howMany; i++)
    buf[i] = Wire.read();  //arduino buf[8] = Wire.read();  //arduino
  flag1 = HIGH;
BTW: You are referred to this link for a tutorial on Master/Slave operations of UNOs.
Thanks all
you helped me to clarify what i had understand wrong
i followed the example of GolamMostafa and it worked fine with my setup.. so i will follow the method of this example for my future project
thanks and for the link... i will check it as soon as possible
