char, byte and String problams
Hi.
I am using the NMEA and the SDuFAT libraries.
I get some arrays of char from the NMEA lib (NMEA terms).
And read an array[512] of byte from the SD card (sector)
All the hardware and the basics are working correctly.
I need to find some of the NMEA terms in the data in the array filled with the SD sector.
I am trying to use the String and Wstring libraries.
strlen, String.contains, String.equals, String.append
But I run into continuous problems with the char, byte or long int definitions, etc.
With the 512 byte sector read I don't have enough RAM space left over (on the 328) to convert the byte array into a char array or define new 512 position strings.
Anybody some advice for a good read-up on this topic ?
Or anybody who can provide some hints or good examples ?
Thanks in advance.
The char and byte types are the same size, and, therefore, represent the same range of values. You should be able to use an explicit cast when a function doesn't like the given type.
char charData[512];
byte byteData[512];
ByteFunction((byte)charData);
CharFunction((char)byteData);
Almost right.
They're the same size, but they don't (in the Arduino implementation) represent the same number range.
The "char" is an eight bit signed datatype (-128..+127), whilst the "byte" is unsigned (0..255).
http://arduino.cc/en/Reference/Char
http://arduino.cc/en/Reference/Byte
char charData[512];
byte byteData[512];
ByteFunction((byte[glow]*[/glow])charData);
CharFunction((char[glow]*[/glow])byteData);
