Hello !
I am trying to write char by char to Serial:
String str = "SET detectionDirection 0";
char c;
for(int i=0; i<str.length(); i++) {
c = str[i].c_str();
USE_SERIAL1.write(c);
and
c = str[i].c_str();
returns
src/main.cpp:827:32: error: request for member 'c_str' in 'str.String::operator[](((unsigned int)i))', which is of non-class type 'char'
Shouldn't it work ?
If this isn't supposed to work, how can I send a String char by char to Serial ?
gfvalvo
2
Two things wrong:
const char * c_str() const { return buffer; }
gfvalvo:
Two things wrong:
And how do I fix it ?
How can I write SET detectionDirection 0 char by char to Serial ?
write also uses const char *:
inline size_t write(const char * s)
char str[] = "SET detectionDirection 0";
for(int i=0; i<strlen(str); i++) {
USE_SERIAL1.write(str[i]);
GeorgeFlorian:
Why do you want to do that? The write() method can take the whole thing and do the looping by itself. Modifying @jremington's example:
USE_SERIAL1.write(str, strlen(str));
Of course, since you'd be sending a c-string, you can just use the print() method:
USE_SERIAL1.print(str);
