Char comparison doesn't work
Hello again!!
I'm sending an AT+CIPSEND=100 command to my ESP. As you may know, the response coming from the module is a '>' char.
Though it is indeed returning it to me, when I try to compare it with a char, string, char[], char* or anything else, it passes by through the condition and it's done.
I'm a bit confused on why this is occuring.
Thanks in advance!
And your code looks like?
We can promise you that char comparison does work
char a = '>';
If (a == '>') {
// do something
// do something else
and string comparison work (use the strcmp function) too...
So you probably did not try it all...
Hi J-M-L,
Thanks for your prompt help. It saved me a lot on my previous post.
I tried using strcasecmp, but somehow it didnt match either.
I tried Serial.find() which search for a char inside a while loop
while ( true )
     Serial.find( '>' );
The first step is to forget that Serial.find() exists. Seriously, I had to look at the reference to be sure you hadn't just made that up.
Then read Serial Input Basics (Updated)
Breno999 provided this:
while ( true )
     Serial.find( '>' );
which is an infinite loop.
The logical condition of the while is always true, and the result of the Serial.find('>') is thrown away without explanation. It will just keep looking, and looking, and looking, and...
