char.isupper
is there an islower() or something to find out if a char is lower or upper case in arduino?
Yes, there is islower(int) and isupper(int).
mkwired:
tyvm for the reply and well im a noob and im doing it wrong cuz when i use isupper(char) i get this error:
‘isupper’ was not declared in this scope. whats the right way?
void setup ()
char c;
isupper (c);
void loop () {}
Gives:
Binary sketch size: 450 bytes (of a 32256 byte maximum)
Now, what's your code?
im trying to use it in a if statement
function go(char* str)
  int len = strlen(str);
  for(int num=0;num<len;++num)
   val = str[num];
   if(isupper(val))
     //do something if its upper
    }else{
     //its not upper
go("asdASD");
sketch_mar22a:-1: error: 'function' does not name a type
sketch_mar22a:0: error: 'function' does not name a type
sketch_mar22a:14: error: expected constructor, destructor, or type conversion before '(' token
What's function?
yeah sry got my langs mixed up there lol, here is the right one.
void go(char* str)
   byte val = str[num];
   if(isupper(val))
    }else{
     //its not upper
go("asdASD");
void go(char* str)
   if(isupper(val))
    }else{
     //its not upper
void setup ()
  go("asdASD");
void loop () {}
Gives:
Binary sketch size: 468 bytes (of a 32256 byte maximum)
Can't reproduce it, sorry.
Umm how could that be?
Well, give more details. Post a complete sketch from start to finish that reproduces your error. Tell us which version of the IDE you are using. What operating system?
yeah i up dated IDE and it works now, thank you very much.
