Good day!
I'm working on reading and writing phonebook entry to sim with a SIM900 gsm shield.
I have done it before but with arduino gsm shield using the gsm library. I had a problem using software serial with the arduino gsm so I switched shield.
Anyway,
I have a problem saving the numbers I have read from the sim. After I have read the second user, the first user's number gets overwritten with the second number.
This is my code:
char Rx_data[50];
unsigned char Rx_index = 0;
int i = 0;
char msg[160];
int sig;
char *adminOneNo;
char *adminTwoNo;
boolean adminOne = false;
boolean adminTwo = false;
int gsm_pin = 13;
int adm1_pin = 12;
int adm2_pin = 11;
Serial1.begin(38400); // GSM
pinMode(gsm_pin, OUTPUT);
pinMode(adm1_pin, OUTPUT);
pinMode(adm2_pin, OUTPUT);
digitalWrite(gsm_pin, LOW);
digitalWrite(adm1_pin, LOW);
digitalWrite(adm2_pin, LOW);
Serial.println("GSM(SIM) READ/ADD PB ENTRY");
initGSM();
readSIM();
void clearSerial(char *data) {
for( int i = 0; i < sizeof(data); ++i )
data[i] = (char)0;
// ----- GSM: TX
void send_msg(char *number, char *msg) {
char at_cmgs_cmd[30] = {'\0'};
char msg1[160] = {'\0'};
char ctl_z = 0x1A;
sprintf(msg1, "%s%c", msg, ctl_z);
sprintf(at_cmgs_cmd, "AT+CMGS=\"%s\"\r\n",number);
sendGSM(at_cmgs_cmd);
delay(300);
sendGSM(msg1);
delay(100);
// ----- GSM: COMM
void sendGSM(char *string) {
Serial1.write(string);
delay(90);
void clearString(char *strArray) {
int j;
for (j = 100; j > 0; j--)
strArray[j] = 0x00;
void send_cmd(char *at_cmd, char clr) {
char *stat = '\0';
while(!stat) {
sendGSM(at_cmd);
delay(90);
readSerialString(Rx_data);
stat = strstr(Rx_data, "OK");
if (clr) {
clearString(Rx_data);
delay(200);
stat = '\0';
void readSerialString(char *strArray) {
if(!Serial1.available()) {
return;
while(Serial1.available()) {
strArray[i] = Serial1.read();
//Serial.print(strArray[i]);
i++;
void initGSM(){
send_cmd("ATE0\r\n",1); // Turn off automatic echo of the GSM Module
send_cmd("AT\r\n", 1);
send_cmd("AT+CMGF=1\r\n", 1); // Sucess
send_cmd("AT+CNMI=1,2,0,0,0\r\n", 1); // Set message format to text mode
Serial.println("Success!\n");
digitalWrite(gsm_pin, HIGH);
delay(2000);
// ----- SIM
void readSIM(){
Serial.println("Reading SIM...");
send_cmd("AT+CPBS=\"SM\"\r\n", 1);
get_no("AT+CPBF=\"User1\"\r\n", 1);
Serial.println("---");
Serial.print(adminOneNo);
Serial.print(", ");
Serial.println(adminTwoNo);
get_no("AT+CPBF=\"User2\"\r\n", 2);
Serial.print(", ");
void get_no(char *user, int admin){
char gsmData[100]; // Reply from SIM
int index = 0;
Serial1.write(user);
delay(90);
delay(3); //delay to allow buffer to fill
if (Serial1.available() > 0) {
char inChar = Serial1.read();
//Serial.print(inChar);
gsmData[index] = inChar;
index++;
String incomingString = String(gsmData);
if (incomingString.length() > 0) {
char *atmessage = strtok(gsmData, "\r\n");
char *reply = strtok(NULL, "\r\n");
//Serial.print("Data from gsm: ");
//Serial.println(incomingString);
if (strcmp(atmessage,"OK") == 0) {
if (admin == 1) Serial.println("User1 does not exist.");
else Serial.println("User2 does not exist.");
else {
Serial.print("\nMessage: ");
Serial.println(atmessage);
Serial.print("Reply: ");
Serial.println(reply);
char *atcommand = strtok(atmessage, "\"");
char *number = strtok(NULL, "\"");
//Serial.print("Command: ");
//Serial.println(atcommand);
//Serial.print("Number: ");
//Serial.println(number);
if (admin == 1) {
adminOne = true;
adminOneNo = number;
digitalWrite(adm1_pin, HIGH);
Serial.print("User1: ");
Serial.println(adminOneNo);
} else if (admin == 2) {
adminTwo = true;
adminTwoNo = number;
digitalWrite(adm2_pin, HIGH);
Serial.print("User2: ");
clearSerial(gsmData);
index = 0;
delay(100);
This is the output:
Success!
Reading SIM...
Message: +CPBF: 3,"xxxxx9556785",129,"User1"
Reply: OK
User1: xxxxx9556785
xxxxx9556785,
Message: +CPBF: 2,"xxxxx5217568",129,"User2"
Reply: OK
User2: xxxxx5217568
xxxxx5217568, xxxxx5217568
The end result should be xxxxx9556785, xxxxx5217568
Is the problem caused by the adminOneNo and adminTwoNo declaration?
I set it as char* because I'll be using a send function that requires this declaration.
