Char Problem SD Card
Hi
I have a problem with my sketch. I read a text from the SD card. Library is SD.h
When I use Serial.print I always get that what I want (say 10 sec) all letters in a new line. This is what I get:
s a y
1 0
s e c
But I want it like this: say 10 sec And I have to use Serial.print and not Serial.write. How can I convert it that the format will be correct?
This is the part of my sketch:
myFile = SD.open("test.txt"); if (myFile) { Serial.println("test.txt:");
// read from the file until there's nothing else in it: while (myFile.available()) { Str1 = myFile.read(); Serial.println(Str1);
} // close the file: myFile.close();
Perhaps you should research the difference between Serial.print() and Serial.println().
Str1 is a stupid name for a character variable. That's like using
int float1;
