Hi
i'm making a clock using an input from the serial port. This input is formatted as following:
i read this feed and convert is to char[] to use it in my arduino sketch.
the receiving part works fine, but i'm having some problems with the decoding.
this is my code:
#include <MI0283QT2.h>
#include "time.h"
MI0283QT2 lcd;
Time time;
int cntr = 0;
lcd.init(2);
lcd.clear(RGB(0,0,0));
if(Serial.available()>0)
char tempTime[11];
for(int i=0; i<11; i++)
tempTime[i]=32;
Serial.readBytesUntil(';', tempTime, Serial.available());
tempTime[10] = '\0';
time.setTimePart(tempTime, cntr);
if(cntr>8)
cntr=0;
cntr++;
lcd.drawText(10,10,time.dayName,1,RGB(60,60,60),RGB(0,0,0));
lcd.drawText(16,23,time.dayNr,3,RGB(60,60,60),RGB(0,0,0));
//lcd.drawText(100,10,"Data received",2,RGB(0,0,0),RGB(0,0,0)); i'll explain this 'outcommenting' later
#ifndef time_h
#define time_h
#include "Arduino.h"
class Time
public:
char dayNr[11];
char dayName[11];
char monthNr[11];
char monthName[11];
char year[11];
char hour[11];
char minute[11];
char second[11];
void setTimeFromData(char DayName[], char DayNr[], char MonthName[], char MonthNr[], char Year[], char Hour[], char Minute[], char Second[]);
void setTimePart(char data[], int cnt);
#endif
#include "time.h"
void Time::setTimeFromData(char DayName[], char DayNr[], char MonthName[], char MonthNr[], char Year[], char Hour[], char Minute[], char Second[])
strcpy(dayName, DayName);
strcpy(dayNr, DayNr);
strcpy(monthNr, MonthNr);
strcpy(monthName,MonthName);
strcpy(year, Year);
strcpy(hour, Hour);
strcpy(minute, Minute);
strcpy(second, Second);
void Time::setTimePart(char data[], int cnt)
if(cnt==1)
strcpy(dayName, data);
if(cnt==2)
strcpy(dayNr, data);
if(cnt==3)
strcpy(monthName, data);
if(cnt==4)
strcpy(monthNr, data);
if(cnt==5)
strcpy(year, data);
if(cnt==6)
strcpy(hour, data);
in the beginning i get what i expect, but it's not how it should be.
as you can see i commented one line out: lcd.drawText(100,10,"Data received",2,RGB(0,0,0),RGB(0,0,0));
this instruction needs to be executed in order to get it to work, if i comment this line out, all i get is garbage (like the year instead of the dayname, and the month instead of the daynr etc etc)
so it's not real garbage, everything just gets mixed up..
i was wondering how this is possible? i only send the input once per second, so it does not get overflowed by serial data (i suppose)
Thanks
Nick
btw, i use the watterott MI0823QT-2 screen, but that doesn't really matter i think
