Char* to float with 6 decimal cases
Hello,
I have a char* named var1 with that value=-39.254563
so I use that double var2=strtod(var1,NULL); but the result is -39.25 only with 2 decimal cases. I want that result: -39.254563 with 6 decimal cases,
How can I make it?
Thank you
Roberto
it should have more decimal places (about 4).
I think there is a bug in your code, please post it so we can help you fix it.
Serial.println (var2, 6);
And now?
serial.print for float defaults to two decimal places. There is a optional parameter it takes to specify more than that.
thanks, is a big code.
that line is the source char*: Lparaconverter=latitude; // here the value is -29.252525
and that line is the conversion error: double Lconvertida=strtod(Lparaconverter,NULL);// after conversion the value is -29.25
char aux_str[30];
char aux;
//char aa;
char* Lparaconverter;
char* Longparaconverter;
double latitudeanterior;
double longitudeanterior;
double valoradicao;
double valorsubtracao;
double somalat;
double somalong;
char latitude[15];
char longitude[15];
int t=0;
int k=0;
int l=0;
char inChar;
int index;
char inData[200];
int i;
l=1;//rastreador foi ligado
latitudeanterior=0.000000;
longitudeanterior=0.000000;
valoradicao=0.000100;
valorsubtracao=-0.000100;
//Init the driver pins for GSM function
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
//Output GSM Timing
digitalWrite(5,HIGH);
delay(1500);
digitalWrite(5,LOW);
// Use these commands instead of the hardware switch ‘UART select’ in order to enable each mode
// If you want to use both GMS and GPS. enable the required one in your code and disable the other one for each access.
digitalWrite(3,LOW);//enable GSM TX?RX
digitalWrite(4,HIGH);//disable GPS TX?RX
delay(20000);
// start_GSM();
delay(5000);
start_GPS();
read_GPS();
delay(2000);
double posicaovazia=0.000000;
double Lconvertida=strtod(Lparaconverter,NULL);//converte a latitude em double
double Longconvertida=strtod(Longparaconverter,NULL);//converte a latitude em double
//float ftemp = atof(aaa);
//double valor=0.000000;
//String str;
//str=String(valor);
if (Lconvertida == posicaovazia) //conta as vezes em que está sem sinal de gps
t=t++;
if (latitudeanterior == Lconvertida)//tempo parado
k=k++;
if (Lconvertida != posicaovazia)//só envia sms se tiver coordenadas
if (latitudeanterior == posicaovazia)// adiciona valor as coordenadas anteriores
latitudeanterior=Lconvertida;
longitudeanterior=Longconvertida;
send_GPRS();
delay(30000);
somalat=latitudeanterior - Lconvertida;
// double sublat = latitudeanterior - Lconvertida;
somalong = longitudeanterior - Longconvertida;
// double sublong = longitudeanterior - Longconvertida;
if (somalat < valorsubtracao || somalat > valoradicao)// se diferença da latitude for mair que 10m
send_GPRS();
delay(30000);
else if (somalong < valorsubtracao || somalong > valoradicao)
send_GPRS();
delay(30000);
void send_GPRS(){
Serial.println(“AT”); //Send AT command
delay(2000);
delay(2000);
//Send message’
Serial.println(“AT+CMGF=1”);
Serial.println("AT+CMGS=“7588746080"”);//Change the receiver phone number
Serial.print(Lparaconverter);
Serial.print(’,’);
Serial.print(longitude);
Serial.print(’,’);
Serial.print(‘2’);//tempo sem sinal gps
Serial.print(’,’);
Serial.print(t);//tempo veiculo parado
Serial.print(’,’);
Serial.print(k);//1 rastreador foi ligado
Serial.print(’,’);
Serial.print(l);//1 rastreador foi ligado
Serial.println("");
// Serial.print(latitude);//the message you want to send
Serial.write(26);
t=0;
k=0;
l=0;
void start_GPS(){
//Configuracion en Inicializacion GPS
Serial.print(“AT”);
Serial.println(“AT+CGPSIPR=9600”);// (set the baud rate)
Serial.println(“AT+CGPSPWR=1”); // (turn on GPS power supply)
Serial.println(“AT+CGPSRST=1”); //(reset GPS in autonomy mode)
delay(10000); //delay para esperar se?al del GPS
void read_GPS(){
Serial.println(“AT+CGPSINF=0”);
read_String();
strtok(inData, “,”);
strcpy(longitude,strtok(NULL, “,”)); // Gets longitude
strcpy(latitude,strtok(NULL, “,”)); // Gets latitude
latitude [14] = ‘\0’;
longitude[14] = ‘\0’;
convert2Degrees(latitude);
convert2Degrees(longitude);
Lparaconverter=latitude; //pega valor para converter em double
Longparaconverter=longitude;
// Lanterior=latitude;
void read_String() {
index=0;
while(Serial.available() > 0) // Don’t read unless
// there you know there is data
if(index < 199) // One less than the size of the array
inChar = Serial.read(); // Read a character
inData[index] = inChar; // Store it
index++; // Increment where to write next
inData[199] = ‘\0’; // Null terminate the string
int8_t convert2Degrees(char* input){
float deg;
float minutes;
boolean neg = false;
//auxiliar variable
char aux[10];
if (input[0] == ‘-’)
neg = true;
strcpy(aux, strtok(input+1, “.”));
strcpy(aux, strtok(input, “.”));
// convert string to integer and add it to final float variable
deg = atof(aux);
strcpy(aux, strtok(NULL, ‘\0’));
minutes=atof(aux);
minutes/=1000000;
if (deg < 100)
minutes += deg;
deg = 0;
minutes += int(deg) % 100;
deg = int(deg) / 100;
// add minutes to degrees
deg=deg+minutes/60;
if (neg == true)
deg*=-1.0;
neg = false;
if( deg < 0 ){
neg = true;
deg*=-1;
float numeroFloat=deg;
int parteEntera[10];
int cifra;
long numero=(long)numeroFloat;
int size=0;
while(1){
size=size+1;
cifra=numero%10;
numero=numero/10;
parteEntera[size-1]=cifra;
if (numero==0){
int indice=0;
if( neg ){
indice++;
input[0]=’-’;
for (int i=size-1; i >= 0; i–)
input[indice]=parteEntera*+‘0’;*
  • indice++;*
  • input[indice]=’.’;*
  • indice++;*
  • numeroFloat=(numeroFloat-(int)numeroFloat);*
  • for (int i=1; i<=6 ; i++)*
    _ numeroFloat=numeroFloat*10;_
  • cifra= (long)numeroFloat; *
  • numeroFloat=numeroFloat-cifra;*
  • input[indice]=char(cifra)+48;*
  • indice++;*
  • input[indice]=’\0’;*
please use code tags to prevent code interpreted as forum tags [ i] -> italic
some demo of decimal places shows the number cannot be represented exactly.
  float f = -29.252525;
  for (int decimals=0; decimals <= 12; decimals++)
    Serial.println(f, decimals);
Hello,
I tried
Serial.println (Lconv, 6);
but receive only 2 decimal.
the problem is here double Lconvertida=strtod(Lparaconverter,NULL) that conversion bring only 2 decimal I don't know why
note that double is same as float on the Arduino UNO and MEGA (AVR based ones)
float == 32 bit IEEE754 , which has a 24 bit mantisse implying max of 7 significant digits.
Therefor the UNO cannot hold longitude/lattitude to the last digit.
this minimal code shows your problem:
  Serial.println("Start ");
  float f = strtod("-39.252525", NULL);
  Serial.println(f, 6);
void loop() {}
output: -39.252521
you might solve it (partly) by using long which has 9 significant digits (multiply by 1000000)
or
by splitting the integer and fractional part in two floats.
if your goal is just to print the value, why not print the string version?
So I need the number with decimals but I don't know how to get it from my code.
What number? Get it from where?
Create a variable and assign it the value returned by strtod(). Then, print something else, and complain that what is printed is not what you want. How useless.
that line convert2Degrees(latitude);, is a result of a char*. I want that value on a variable, float or double, or int, because I want compare wth other value. the value sample is: -12.584745,
Serial.println("AT+CGPSINF=0");
read_String();
strtok(inData, ",");
strcpy(longitude,strtok(NULL, ",")); // Gets longitude
strcpy(latitude,strtok(NULL, ",")); // Gets latitude
latitude [14] = '\0';
longitude[14] = '\0';
Double is the same as float on an Arduino, and each number can represent at most about 6-7 decimal digits. This number format does not have the accuracy to store latitude and longitude to the precision you want.
What are you talking about? convert2Degrees() might RETURN a char *, but the function is not the result of a char *.
Actually, no it doesn't. It returns a byte. WTF?
On further examination, the function is crap, since it doesn't return anything.
