char to SMS and memory question
I use the following code in a project. I would like to add the temperature in de tekst from "char txtSMS_AlarmTemp" to send it in the SMS. How to do this?
I have also a question about the memory. I get a message of low memory on my UNO that is almost full. What to can i do to solve this problem.
//librarys
#include <GSM.h>
#include <OneWire.h>
#include <DallasTemperature.h>
////Telefoon
// PIN SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
////Temperature
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//Hardware adres DS18B20 PIN 4
DeviceAddress Thermometer = { 0x28, 0xBF, 0x64, 0xA3, 0x06, 0x00, 0x00, 0xC3 };
//Variable
float TEMPAlarm = 10.00;
//Telefoon nummers
char tel1[20]= "+3165********";
//Global files
byte  ALARM_FLAG = 0;
//meldingenen
char txtSMS_Online[200]="<> Status Online";
char txtSMS_AlarmTemp[200]="ALARM de temperatuur is gezakt onder de ingestelde waarde";
char txtSMS_AlarmSensor[200]="ALARM temperatuur sensor niet gedetecteerd";
void setup(void)
  // start serial port
  Serial.println("<> Aan");
  // Start library
  sensors.begin();
  // set the resolution to 10 bit (good enough?)
  sensors.setResolution(Thermometer, 10);
  //SIMmodule
 // connection state
  boolean notConnected = true;
  // Start GSM shield
  while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  //SMS Online
  Serial.println("GSM initialized");
  sendSMSOnline();
// Temperatuur sensor
void printTemperature(DeviceAddress deviceAddress)
  float tempC = sensors.getTempC(deviceAddress);
  if (tempC < -100.00) {
    Serial.print("Sensor is niet verbonden 1e controle");
    sendSMSAlarmSensor();
  else if (tempC <= (float) TEMPAlarm) {
    Serial.print("C: ");
    Serial.print(tempC);
    ALARM_FLAG = 1;
    else {
    Serial.print("Het is niet kouder dan de ingestelde waarde, het is nu *C ");
void loop(void)
  Serial.print("Meten...\n\r");
  sensors.requestTemperatures();
  Serial.print("Temperature ");
  printTemperature(Thermometer);
  Serial.print("\n\r");
  if ( ALARM_FLAG == 1 ) {
    Serial.println("Alarm Activated");
    sendSMSTempAlarm();
    else if ( ALARM_FLAG == 3 ) {
    Serial.println("Alarm Activated ");
    sendSMSTempAlarm();
  delay (59000);
void sendSMSOnline(){
  Serial.print("Message to mobile number: ");
  Serial.println(tel1);
  // sms text
  Serial.println("SENDING");
  Serial.println("Message:");
  Serial.println(txtSMS_Online);
  // send the message
  sms.beginSMS(tel1);
  sms.print(txtSMS_Online);
  sms.endSMS();
  Serial.println("\nCOMPLETE!\n");
void sendSMSTempAlarm(){
  // sms text
  Serial.println(txtSMS_AlarmTemp);
  // send the message
  sms.beginSMS(tel1);
  sms.print(txtSMS_AlarmTemp);
  sms.endSMS();
  ALARM_FLAG = 2;
    delay (120000); // 2 min
void sendSMSAlarmSensor(){
  // sms text
  Serial.println(txtSMS_AlarmSensor);
  // send the message
  sms.beginSMS(tel1);
  sms.print(txtSMS_AlarmSensor);
  sms.endSMS();
  ALARM_FLAG = 3;
The compiler can count better than you can. Instead of reserving 600 characters, let the compiler reserve on the needed space.
Where in that text?
tempC is local to the printTemperature() function, which, obviously, needs a better name as the function does a lot more than print the temperature. So, you'd need to get the value into a string, using dtostrf(), and make that string part of the text in txtSMS_AlarmTemp using sprintf(). In that case, txtSMS_AlarmTemp does need to have a size defined, and the size needs to accommodate the text that is there and the text that dtostrf() will create.
