I am given a message "70.0,95,15:00" which tells me the temperature and humidity at a specific time. I want to access this message piecewise. So for example I want to print the temperature and the humidity separately on the serial monitor.
I have tried the following code. Can anyone help me figure out what's wrong?
int FindCharacter(char msg[], char c);
char message[] = "70.0,95,15:00";
int index;
int holdIndex = 0;
int temperature;
int humidity;
index = FindCharacter(message, ',');
if(index > '0'){
message[index] = '\0';
temperature = atoi(message);
holdIndex += index + 1;
index = FindCharacter(message + holdIndex, ',');
if(index > '0') {
humidity = atoi(message + holdIndex);
Serial.print("The temperature is = ");
Serial.print(temperature);
Serial.print(" with humidity = ");
Serial.print(humidity);
Serial.print(" at ");
Serial.print(message + holdIndex);
// put your main code here, to run repeatedly
Purpose: Look for a specific character in a string
Parameter list:
char msg[] an array of characters, null terminated
char c the char to find
return value:
int the position in the string where found or 0 if no match
int FindCharacter(char msg[], char c) {
int i = 0;
while(msg) {
if(msg[i] == c){
return i;
}else{
i++;
return 0;
For your application even strchr() is enough, which you kind of reinvented in your sketch.
I think using a float to parse the temperature would be better.
float temperature = -999;
int humidity = -1;
char * ptr = nullptr;
Serial.begin(250000);
temperature = strtod(message, &ptr);
if (*ptr == ',') {
humidity = atoi(++ptr);
ptr = strchr(ptr, ',');
if (ptr) {
ptr++;
Serial.print(F("The temperature is = "));
Serial.print(temperature, 1);
Serial.print(F(" with humidity = "));
if (ptr) {
Serial.print(F(" at "));
Serial.print(ptr);
void loop() {}
The temperature is = 70.0 with humidity = 95 at 15:00
@ Whandall: Your solution is really neat, thx so much! I mean, I'm a programming beginner, so would you mind explaining to me why you initialized temperature = -999, humidity = -1 and char * ptr = nullptr ?
I have just run the code and it works without this initialization as well..
int i = 0;
while(msg) {
if(msg[i] == c){
return i;
}else{
i++;
return 0;
0 is a crappy value to mean "not found" since the character being looked for COULD be in the 0th position of the array. With this code, you can't distinguish between not found and found in the 0th element.
