Hello Everyone,
What I am trying to do: I want my arduino to receive a message from my computer and output a PWM value on digital pin 3 according to the message received. the message sent from the computer always takes the form of where A will always be a 0 or a 1 and BBB is the three digit value of the PWM signal (0 <= BBB <= 255). The A value is whether the pin is on or off, and the BBB value is the PWM value.
I need to get the AAA into an integer to be sent to the pin ← my problem
What I have done so far: Here is my code in its entirety
/* Aug 21 2012
Joystick read and serial send
This program attempts to read a joystick value and send it over the serial port
This one is working
#include <Bounce.h> // debouncing
#include <serLCD.h> // serial LCD from SparkFun
#include <SoftwareSerial.h> // Software Serial (for LCD)
// INPUTS
#define JoyPin 0 // Horizontal joystick ANALOG pin 0
#define PWMlitePin 3 // pin to write PWM on
// Variables
int JoyPot; // the joystick potentiometer value returned by the arduino
int JoyVal; // the value from the potentiometer mapped to a value (below I use 100 - 600)
int OldJoyVal = 0; // used to look for a change in value
int JoyDiff; // difference in readings
int LiteVal; // PWM value for light brightness
int LitePow; // led power
int LEDPower = 1;
boolean started = false;
boolean ended = false;
char inData[3]; // array to hold serial data sent from LabView
char LiteValArray[2];
byte index; // keep track of scribing the serial data
pinMode(JoyPin, INPUT);
pinMode(PWMlitePin, OUTPUT);
Serial.begin(38400);
Serial.flush();
JoyPot = analogRead(JoyPin); // read the input pin
JoyVal = map(JoyPot, 0, 1023, 100, 600);
JoyDiff = abs(JoyVal - OldJoyVal);
if(abs(JoyVal - OldJoyVal) > 0)
//Serial.print("*"); Serial.print(JoyVal); Serial.print("+"); //Serial.print("Hello");
OldJoyVal = JoyVal; // keep track of the last reading
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '<')
index = 0;
started = true;
ended = false;
else if (inChar == '>')
ended = true;
if (index <= 3)
inData[index] = inChar;
index++;
if (started && ended)
for(int i = 0; i < 3; i++)
LiteValArray[i] = inData[i+1];
LiteVal = atoi(LiteValArray);
if (inData[0] == '1')
analogWrite(PWMlitePin, LiteVal);
Serial.print("+"); Serial.print(LiteValArray); Serial.print("-"); Serial.print(inData); Serial.print(":"); Serial.println(sizeof(inData));
else if (inData[0] == '0')
analogWrite(PWMlitePin, 0);
started = false;
ended = false;
index = 0;
There is some other stuff in there that is working and is independent of this problem. The area of the code that we are concerned with is here;
if (inChar == '<')
index = 0;
started = true;
ended = false;
ended = true;
if (index <= 3)
index++;
started = false;
ended = false;
index = 0;
The problem is that the inData array gets jumbled / modified by the line
If that for loop is commented out (eliminated), the inData array is returned exactly as I sent it (for example, If I send <1231>, the debugging line Serial.print("+"); Serial.print(LiteValArray); Serial.print("-"); Serial.print(inData); Serial.print(":"); Serial.println(sizeof(inData));
returns +1-1231: (1231 is the inData Array)
When I run that for loop and again send <1231>, the same debugging line returns +232-123232:3
What I don’t understand is I am not modifying inData, although it gets returned now as a six digit number, yet the size stays the same (3). Also, sending different values of BBB always returns a number in inData that only change in multiples of 10. For example, sending BBB as any number between 230 and 239 always returns +232-123232:3, and sending BBB as any number between 240 and 249 always returns +242-124242:3,
One of the high lords of this forum has a signature that says “measurement modifies behavior”, and this problem makes me think of that statement.
What am I doing wrong?
