Hi all, i'm 25y.o. and i'm noob in programming and electronic. So my question will probably be as noob as i am!
Let's say i have 2 battery pack, built with 3 cells called ( First CLS1 CLS2 CLS3 ) ( Second CLS4 CLS5 CLS6) every cell reach full charge at 1.2volt.
I want to plug a triple power source to arduino that we call CGR1 CGR2 CGR3
Arduino must listen voltage, and when all tree cells of the first pack is 1.2volt each, COMMUTE the power supply to second pack, letting the first unplugghed and unlinked to the circuit.
Is that possible? Because if it is, i will start learning something, even if this programming language for me is really unfamiliar and not ME-friendly.
It will NOT be easy for Arduino to accurately measure the individual cell voltages. Presumably the balancer/charger is handling that? Of course
Is the balancer/charger smart enough to stop by itself when the cells/battery are fully charged? Yes the charger stop charging at 4.2volt
Do you need to control the charger? No the meaning of this project is this, not to control the charger but charghing as many cell i want.
Do you need to handle long-term maintenance (go back every few hours to see if the battery is still there and needs more). same as above the meaning of this project is this, not to control the charger but charghing as many cell i want.
Can the Arduino be powered directly from cells? That would be awesome.
Max Voltage each cell 4.2 volt, the charger will stop rechargin mantaining the cells to 4.2 volts
Time before switchin to other battery when reached 4.2 volt: 5 minutes
After 5 minutes are passed switch to other battery.
