Charging a nimh 11,5 wh. 7.2v battery while wired to arduino.
a
put a switch on the battery? Hard to tell without a circuit diagram. But if you disconnect it with a switch you should be able charge a battery without physically disconnecting it from your circuit.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
http://forum.arduino.cc/index.php/topic,148850.0.html.
It will tell you how to post/attach files.
Thanks.. Tom.. :slight_smile:
OP's image:
OPs circuit.
First you need a base series resistor to protect your Nano's output pin.
Where is your rechargeable battery?
Tom... :slight_smile:
