dear anyone,
Am I right if i state this:
If I make a brand new battery pack with 3 cells in series (3S)
I am able to charge them at a voltage of 12.6 volts with a board such as this one:
but the board deactivates the battery charging as soon as one of the cells reached 4.2 volts.
and also deactivates the batteries when one is under 2.3 volts.
but it doesn't charge all of the to 4.2V only 1 so one can be at 3.8V when the other is at 4.2V
(This shouldn't be a problem if you bought them new but after charging the all a few times differences may occur.)
so far so good right?
okay here it comes:
If I disconnect all the cells from their sockets when the difference gets to big and than charge them all with a 1S charger such as this one:
http://www.ebay.com/itm/USB-5V-1A-1S-3-7V-Li-ion-Lithium-18650-Battery-Charging-Module-Charger-Board-/172451426542?var=&hash=item2826e7f0ee:m:mPRLwz0nWfXKyYNqIyta1-A
all at the same time they should all reach 4.2 volts because they are charged separately.
If I put the cells back into the 3S formation the should be "reset" so to say.
now they all discharge and reach 2.3 volts at approximately the same time and when charged 4.2V at approximately the same time.
Right? I'm not so sure but almost sure just asking someone with more experience than me to help me...
yours faithfully,
-Maarten
