Charlie-plexing LRAs
I'm working on a project where I imbed small vibrating motors (Linear Resonant Actuators) into an elastic sleeve to use in a haptic feedback system. I have 20 motors, so 5 pins on the arduino. Now that the sleeve is wired, I can't get the motors to activate. I've tested with a multimeter to confirm a connection all through the sleeve and I've tested each motor individually. Might there be a power issue? Any tips would be helpful. I'm new to these concepts. Lets me know if you need more specs.
I'm using these motors: https://www.adafruit.com/products/1201
I see the problem!
You do not have a circuit diagram.
Without a circuit diagram, it just won't work.
Hi, are you saying you did not test the charlieplexing circuit on breadboard before you wired up the sleave?
Paul
