Sorry about the vid. I guess I need to stop putting music to them.
I built this:
The pins at the bottom are numbered in the order they connect to the 85. I'm just trying to get something working with 12 leds for now.
I found some code that compiled and loaded fine but damned if I can get it to work properly...
the matrix is like this (led ground is the first number):
Led1-2,3
Led2-1,3
Led3-0,3
Led4-0,2
Led5-1,2
Led6-3,2
Led7-2,1
Led8-0,1
Led9-3,1
Led10-2,1
Led11-1,0
Led12-3,0
This is the sketch I'm playing with:
#include <avr/pgmspace.h> //This is in the Arduino library
int pins[4];
int blinkdelay = 200; //This basically controls brightness. Lower is dimmer
int runspeed = 150; //smaller = faster
const int ledPins[12][2] ={ // This stores the led pins order NOTE:You may need to change the order of these
3,2 } //1
3,1 }//2
3,0 }//3
2,0 }//4
2,1 }//5
2,3 }//6
1,2 }//7
1,0 }//8
1,3 }//9
1,2 }//10
0,1 }//11
0,3 }//12
byte displays[][12] PROGMEM ={ // This stores the array in Flash ROM. You can easily have 500+ frames.
//left right blinking
{0,1,1,1,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,1,1,1,0},
// out in blinking
{0,0,0,0,0,1,1,0,0,0,0,0},
{1,1,0,0,0,0,0,0,0,0,1,1},
// counting in binary
{0,0,0,0,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,0,0,0,1},
{0,0,0,0,0,0,0,0,0,0,1,0},
{0,0,0,0,0,0,0,0,0,0,1,1},
{0,0,0,0,0,0,0,0,0,1,0,0},
{0,0,0,0,0,0,0,0,0,1,0,1},
{0,0,0,0,0,0,0,0,0,1,1,0},
{0,0,0,0,0,0,0,0,0,1,1,1},
{0,0,0,0,0,0,0,0,1,0,0,0},
{0,0,0,0,0,0,0,0,1,0,1,0}
// The setup() method runs once, when the sketch starts
// initialize the digital pin as an output:
pins[0] = 0;
pins[1] = 1;
pins[2] = 2;
pins[3] = 3;
sequenceon(); // Does one loop of the cylon effect
// the loop() method runs over and over again,
// as long as the Arduino has power
sequenceon(); //Turns on cylon effect
// displayChar(0,1, 100); //In/out blinking
// displayChar(4,14, 200); //Counts to 15 in binary
void displayChar(int from, int through, int tranSpeed)// loads a Pattern from above. From & though spesify what patterns to show. tranSpeed is the speed of the frames
boolean run = true;
byte k;
int t = from;
while(run == true)
for(int i = 0; i < tranSpeed; i++)
for(int j = 0; j < 12; j++)
k = pgm_read_byte(&(displays[t][j]));
if (k == 2)
run = false;
else if(k == 1)
turnon(j);
delayMicroseconds(blinkdelay);
alloff();
else if(k == 0)
if(through == t){
return;
t++;
void ledSpecify(int highPin, int lowPin) // This allows you to manually control which pin goes low & which one goes high
for(int i; i < 4; i++){
pinMode(pins[i], INPUT);
pinMode(pins[highPin], OUTPUT);
digitalWrite(pins[highPin], HIGH);
pinMode(pins[lowPin], OUTPUT);
digitalWrite(pins[lowPin], LOW);
void turnon(int led) // This turns on a certian led from the list of leds
int pospin = ledPins[led][0] + 2;
int negpin = ledPins[led][1] + 2;
pinMode (pospin, OUTPUT);
digitalWrite (pospin, HIGH);
pinMode (negpin, OUTPUT);
digitalWrite (negpin, LOW);
void alloff() // This turns all the LED's off
for(int i = 0; i < 5; i++)
pinMode (pins[i], INPUT);
void sequenceon() // This handles the cylon effect
for(int i = 0; i < 12; i++)
turnon(i);
delay(100);
alloff();
for(int n = 10; n > 0; n--)
turnon(n);
delay(100);
alloff();
Ye Olde Charlieplex schematic:
I just noticed that the 85 only has 3 analog inputs and I'm only using 1. Not sure if that's part of the problem...
I figured I'd change the thread title because this is what It's morphed into.
New matrix schematic:
In the code where the pins are listed in order does the cathode or anode go first?
