Hope someone finds this stuff useful...
Cut and paste the following into the Arduino Editor, read the comments for details on wiring up the LEDs.
This program toggles the state of 4 leds through 16 combinations
using only 3 pins (without exclusive ground). This project was a proof of concept for implementation
of "charlieplexing"; multiplexing using dynamic use of anode and cathode- resulting in
efficient utilisation of pins for driving LED displays in a multiplexed mode.
Only one LED is on at any one time. The LEDs are flashed
alternately at a rate that achieves persistence of vision.
Known problems: This version of the program results in minor residual LED illumination
arising from sync issues during the switching phase.
Connect four LED's to your Arduino...
LED1: Cathode to pin 6, Anode to pin 5
LED2: Cathode to pin 5, Anode to pin 6
LED3: Cathode to pin 7, Anode to pin 6
LED4: Cathode to pin 6, Anode to pin 7
Todo: Rewrite in assembly, using timer interrupt to service LED sequencing.
Written by Hoastey, October 2007
int ledPina=5;
int ledPinb=6; /* Use pins 5, 6 and 7 */
int ledPinc=7;
const int dly=100; /* delay time /
const int mpxdly=1; / multiplexed delay time */
pinMode(ledPina, OUTPUT); /* Set the Arduino pins for output */
pinMode(ledPinb, OUTPUT);
pinMode(ledPinc, OUTPUT);
void loop() /* Sequence through all the LED combinations */
state(0,0,0,0,dly); // zero
state(0,0,0,1,dly); // one
state(0,0,1,0,dly); // two
state(0,0,1,1,dly); // three
state(0,1,0,0,dly); // four
state(0,1,0,1,dly); // five
state(0,1,1,0,dly); // six
state(0,1,1,1,dly); // seven
state(1,0,0,0,dly); // eight
state(1,0,0,1,dly); // nine
state(1,0,1,0,dly); // ten
state(1,0,1,1,dly); // eleven
state(1,1,0,0,dly); // twelve
state(1,1,0,1,dly); // thirteen
state(1,1,1,0,dly); // fourteen
state(1,1,1,1,dly); // fifteen
Set LED state.
Accepts status for led1, led2, led3 and led4 (1=on, 0=off) and period (length of display)
void state(boolean led1, boolean led2, boolean led3, boolean led4, int period)
for(int i=0; i<period; i++)
if (led1==1) {
digitalWrite(ledPina, HIGH);
digitalWrite(ledPinb, LOW);
digitalWrite(ledPinc, LOW);
else {
digitalWrite(ledPina, LOW);
delay(mpxdly);
if (led2==1) {
digitalWrite(ledPinb, HIGH);
digitalWrite(ledPinc, HIGH);
else {
delay(mpxdly);
if (led3==1) {
else {
delay(mpxdly);
if (led4==1) {
else {
delay(mpxdly);
Regards,
Hoastey.
