Charliplexing/Multiplexing?
I have made a LED matrix - size 12 by 5 using blue LEDs. Now, other than shift registers, there are two other ways I can control the LEDs: Charlieplexing or Multiplexing.
I was thinking of Charliplexing, but the problem is this: I have 9 pins available on my Arduino (UNO). The formula for charliplexing
is :
Number of LEDs = Pins available * (Pins available-1)
That substitutes to Number of LEDs = 9 * (9-1) = 72.
Now you may be thinking, " Hey, that's alright, you just have 60 LEDs!"
If I add one more pushbutton in another version of this clock, that makes it 8 * (8-1) = 56.
Should I still stick with Charlieplexing or should I switch to Multiplexing?
(Also, I can't post a picture of the circuit because I am having this poblem with the circuit. The circuit and the code will depend upon whether I use Charliplexing or Multiplexing.
Frankly, I think you should be using a MAX7219.
Pretty much all problems solved in one go - multiplexing, driver transistors, current control, three pins to operate.
Paul__B:
Sorry but I cannot use any external ICs. Only either Charlie or Multiplexing.
Arduinoisme:
Well, if you cannot use any external ICs, then presumably you cannot afford driver transistors either because they are going to take up the same amount of "real estate" as a MAX7219 or TPIC6B595, so you are going to be stuck with limited brightness from the LEDS - though for a clock that should not matter much.
On a UNO, you have 20 digital pins, with two generally reserved for the serial interface. I am wondering what you are using the other nine for if you say you have only nine available for the display?
To "straight" multiplex, you would need at minimum sixteen pins - eight rows, eight columns, so that is simply not an option anyway; that much is solved. To "Charlieplex", you need nine pins and you will be using a one in nine multiplex and the safe current draw on an Arduino pin being 20 mA, each of the eight possible LEDs in a given row can be allocated 2.5 mA and the average drive current per LED is then one ninth of that - less than 0.3 mA.
Note by the way, that if you are multiplexing or Charlieplexing directly from the Arduino, you can multiplex up to eight or nine pushbuttons (with a diode for each) on a single port pin.
With Charlieplexing you can control LEDs AND read input switches in the same matrix:
For times when you need to control several LEDs (up to 8) with just 2 pins I invented GraciePlexing:
