ChatGPT generated code doesn't work
No, I didn't expect anything. I ASKED if someone could see what was wrong. Some did, some started bickering instead.
Thanks anyway (and I really mean that)!
I invite you to take part in the 'ban chatGPT' discussion I linked to.
Maybe the serial print doesn’t work because you- er, chatGPT used
Serial.print(“text…”);
Instead of
Serial.println(“correctly printed text…”);
Personally, I think there should be a separate forum here for help with AI-generated code. I find it ridiculous that someone would be so lazy they are not willing to learn even the most fundamental aspects of C++, then ask for help with code they did not write.
Perhaps, but it's hard enough getting people to post in the correct category now!
I don't know what's required, as a process, to steer misplaced topics over to appropriate categories, but if it would make it easier to do so by burning the Replies (vis-a-vis chatGPLazy) - I'd be fine with that.
I think you speak a different dialect of English to me; I've read that several times and still don't know what it means.
Edit thing next to your username, select the appropriate category, save. I think you can do it with your own topics. It's easy enough, but annoying to keep doing it, especially if people post in uncategorised, where it clearly says not to.
I might start said forum if it doesn’t already exist.
Don’t tell the corporate managers, they wanted to get rid of thinking workers.
