Cheap alternative to TIP117 pnp tranzistor which has same pinout
Hi all!
I've built pcb according to this design:
Only problem is that I can't find TIP117 in my local store, and on ebay is delivery pretty expensive.
Thing is that I have the LED brake light which consumes less than 0.3A so I don't need anything special, just with same pinout because I'm already built the PCB. I live in Croatia so best would be to order from ebay.
Thanks
I found this one on ebay and it should work:
http://www.ebay.com/itm/5Pcs-TIP127-TO-220-100V-5A-Transistor-Complementary-PNP-/130817690659?pt=LH_DefaultDomain_0&hash=item1e75578c23
So, problem is solved!
