Can't get much cheaper than a voltage divider; just make sure that your 12V input really is 12. In case it can be a little high, you may want to choose resistors to drop it a little lower than 5V - it'll still register as high.
For extra protection you could connect a 5.1V Zener diode between the Arduino input and ground (as well as using the voltage divider). This should help protect the Arduino from any excess voltages or spikes.
Paul
wildbill: Can't get much cheaper than a voltage divider; just make sure that your 12V input really is 12. In case it can be a little high, you may want to choose resistors to drop it a little lower than 5V - it'll still register as high.
A good point.. The 12V is not constant all the time.. It sometimes rises to 16V too..
So I guess, there is a problem with the voltage divider..:(
Another option is a resistor and a pair of [u]protection diodes[/u] (the 2nd schematic on that page). I'd use a larger resistor (at least 10K) and you can leave out D2 if you're sure the input will never go negative.
Or, you can also use a voltage divider with one or two "protection diodes". (That's the same protection circuit with a 2nd resistor in parallel with D2.)
A voltage regulator is designed for power, not data. It's not fast enough for normal digital data and it could potentially load-down a data line. It's just the part for this application.
I finally decided to use the 7805 SOT89 package, as I am working on SMD board and the space is a real issue.
I don't think a voltage regulator is the right application, as DVDdoug already told you. It's a shame that you didn't listen. Voltage regulators are designed to POWER something. They are never used to regulate the voltage on a data line. Good luck making that work.
Any SOT23 MOSFET could also have been used.
Use the 12-16V to drive an optoisolator, on the output side pull the open collector low on an arduino input with pullup resistor enabled.
CrossRoads:
… which will reverse the logic, but you can take care of that in code. If that’s an issue, use an external pulldown to keep the logic the same way round.
A 4.5v ish zener diode and a zener should do the job...
Take a look at v-usb which uses a zener to knock the data lines down to 3v from 5v, the same can be applied here a couple (guessing 200 to 500) resistors.
How's this?
Joy: I finally decided to use the 7805 SOT89 package, as I am working on SMD board and the space is a real issue.
Then you have made the wrong decision and made yourself look foolish.
As per CrossRoad's suggestion (several variations):
Voltage swing at Arduino input: 0 to 4.9V (see Fig. 6 here).
Xpendable: I don't think a voltage regulator is the right application, as DVDdoug already told you. It's a shame that you didn't listen. Voltage regulators are designed to POWER something. They are never used to regulate the voltage on a data line. Good luck making that work.
Actually I am not using it to trigger any arduino pin.. I am using a 8 PIN PIC with a very tiny PCB.. Space is a real issue. So if I am using a SOT-89 7805 I do not require any other component.
I definitely agree that using an Optoisolator is the best option, but it requires many other components too and will occupy lil larger space than what the SOT-89 7805 will occupy.
So what are you using it for?
Cheap, good and small: SOT-89 (7805): 1.6mm x 4.6mm, area 7.36mm2, SOT-416 (DTC114W): 1.7mm x 0.9mm, area 1.53mm2, $0.20 each I/O Connections: VIN 0-30V, OUT (inverted) connected to PIC input with Pull-up enabled.
Grumpy_Mike:
I have mentioned it on my previous post. I am actually using it to trigger a SMD 8 Pin PIC Microcontoller..
The main target is to make the PCB as tiny as possible and making it cheap retaining the quality, as it will be mass produced..
dlloyd: Cheap, good and small: SOT-89 (7805): 1.6mm x 4.6mm, area 7.36mm2, SOT-416 (DTC114W): 1.7mm x 0.9mm, area 1.53mm2, $0.20 each I/O Connections: VIN 0-30V, OUT (inverted) connected to PIC input with Pull-up enabled.
I am unable to make out how will it work.. I went through the datasheet too, bu cant make out..It would be kind of you, if you can elaborate please..
Hint: The 7805 has 3 terminals (INPUT, OUTPUT, GND). The DTC114W has 3 terminals (IN, OUT, GND).
What does that mean? By trigger do you mean turn on, like applying power controlled by something else?
That sounds like an even worse idea.
