16 LEDs run through shift registers for sequencing control
LCD display
rotary encoder for multi purpose tweaking
stylophone keyboard
expression control through body switches
wireless receiver and transmitter through infrared light (control your synth with your remote control!)
passive volume control
5 navigational keys and 1 home key (can be expanded with shoulder keys)
sound circuit and code based on the arduino pocket piano project.
making PCBs now, will soon have some more tight versions of this little frankensynth! the plan is - with time - to create a kit of this prototype, if you have feedback or ideas, please share.
yeah, its superbig. hopefully the PCB version should make up for that!
the LCD display is not of too much use right now (except for bling, which is, after all, really important) but it is the idea that the LCD combined with the rotary encoder, will let you adjust settings.
i need to code all of these behaviours with time. the idea right now is to design a platform for musical experimentation, which is open and flexible.
/j
seems a bit more complicated but there's some not so complicated "super alpha pair" to take back their words that sould make the jobs
you could even use something like Antistatic device - Wikipedia for a common connection... that seem more confortable than using a connector on your pcb keyboard...
