The sensor will make a vieuw of the room in the first seconds it's powered up.
When there is a detection, it will set it's output pin to LOW.
So a pull up resistor is required.
A simple code like this would give you an alarm over serial
int pirPin = 2; //digital 2
void setup(){
pinMode(pirPin, INPUT);
void loop(){
int pirVal = digitalRead(pirPin);
if(pirVal == LOW){ //was motion detected
Serial.println("Motion Detected");
delay(2000);
The code is from a bildr.org tutorial on a simular sensor
http://bildr.org/2011/06/pir_arduino/
