Hi guys. I'm new to this but I still wanted to try.
A few weeks ago I received this cheap smartwatch as a gift but the software was really crap. I took it apart to look inside and I found this.
It may not even be possible to "dump the firmware". Even if you manage to correctly identify the proprietary processor, most commercial devices have code copy protection.
What are you hoping to do with the firmware should you be able to extract it, bearing in mind that it will be the compiled binary code rather than the source code
maaan idk it's one of the thousand of cheap smartwatch on the market. The model itself is LB728(D) but I didn't find anything about it. I found a chip called HS6620. I think it can be useful
You could buy those eeprom readers off aliexpress and check if the smartwatch have the option to update it(you could put your code there) and you can also see if its a rom memory or rewriteable memory
You can salvage the battery and speaker, but it will be really hard to reprogram the device.
You might be able to salvage the display if you are lucky.
