I have this cheap SSD1963 7in display.
display
The end use driver will be a teensy 4.1 but im just tinkering with an arduino mega to learn the UTFT library till i get the teensy.
I have the display wired like the documentation in the UTFT explains.
Im feeding the Display 5v on the LED_A pin, 5V pin beside that for the backlight and 3.3V on the designated pin.
I have the RD pin pulled up with a 3.3v feed.
While using the SSD1963 480x800 example i get a few screen wipes where the brightness fades from right to left, some individual dot lines will show vertically and some other faded nonsense. No text no exact shapes etc.
Here is the code
/ UTFT_Demo_800x480
// Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
// web: http://www.RinkyDinkElectronics.com/
// This program is a demo of how to use most of the functions
// of the library with a supported display modules.
// This demo was made for modules with a screen resolution
// of 800x480 pixels.
// This program requires the UTFT library.
#include <UTFT.h>
// Declare which fonts we will be using
extern uint8_t SmallFont[];
// Set the pins to the correct ones for your development shield
// Arduino Uno / 2009:
// Standard Arduino Uno/2009 shield : <display model>,A5,A4,A3,A2
// DisplayModule Arduino Uno TFT shield : <display model>,A5,A4,A3,A2
// Arduino Mega:
// Standard Arduino Mega/Due shield : <display model>,38,39,40,41
// CTE TFT LCD/SD Shield for Arduino Mega : <display model>,38,39,40,41
// Remember to change the model parameter to suit your display module!
UTFT myGLCD(SSD1963_800ALT,38,39,40,41);
randomSeed(analogRead(0));
// Setup the LCD
myGLCD.InitLCD();
myGLCD.setFont(SmallFont);
int buf[798];
int x, x2;
int y, y2;
int r;
// Clear the screen and draw the frame
myGLCD.clrScr();
myGLCD.setColor(255, 0, 0);
myGLCD.fillRect(0, 0, 799, 13);
myGLCD.setColor(64, 64, 64);
myGLCD.fillRect(0, 466, 799, 479);
myGLCD.setColor(255, 255, 255);
myGLCD.setBackColor(255, 0, 0);
myGLCD.print("* Universal Color TFT Display Library *", CENTER, 1);
myGLCD.setBackColor(64, 64, 64);
myGLCD.setColor(255,255,0);
myGLCD.print("<http://www.RinkyDinkElectronics.com/>", CENTER, 467);
myGLCD.setColor(0, 0, 255);
myGLCD.drawRect(0, 14, 799, 465);
// Draw crosshairs
myGLCD.setBackColor(0, 0, 0);
myGLCD.drawLine(399, 15, 399, 464);
myGLCD.drawLine(1, 239, 798, 239);
for (int i=9; i<790; i+=10)
myGLCD.drawLine(i, 237, i, 242);
for (int i=19; i<470; i+=10)
myGLCD.drawLine(397, i, 402, i);
// Draw sin-, cos- and tan-lines
myGLCD.setColor(0,255,255);
myGLCD.print("Sin", 5, 15);
for (int i=1; i<798; i++)
myGLCD.drawPixel(i,239+(sin(((i*1.13)*3.14)/180)*200));
myGLCD.setColor(255,0,0);
myGLCD.print("Cos", 5, 27);
myGLCD.drawPixel(i,239+(cos(((i*1.13)*3.14)/180)*200));
myGLCD.print("Tan", 5, 39);
myGLCD.drawPixel(i,239+(tan(((i*0.9)*3.14)/180)));
delay(2000);
myGLCD.setColor(0,0,0);
myGLCD.fillRect(1,15,798,464);
// Draw a moving sinewave
x=1;
for (int i=1; i<(798*20); i++)
x++;
if (x==799)
x=1;
if (i>799)
if ((x==399)||(buf[x-1]==239))
myGLCD.setColor(0,0,255);
myGLCD.drawPixel(x,buf[x-1]);
y=239+(sin(((i*1.65)*3.14)/180)*(200-(i / 100)));
myGLCD.drawPixel(x,y);
buf[x-1]=y;
delay(2000);
// Draw some random filled rectangles
for (int i=0; i<50; i++)
myGLCD.setColor(random(255), random(255), random(255));
x=2+random(746);
y=16+random(397);
x2=x+50;
y2=y+50;
myGLCD.fillRect(x, y, x2, y2);
delay(2000);
// Draw some random filled, rounded rectangles
x=2+random(746);
y=16+random(397);
x2=x+50;
y2=y+50;
myGLCD.fillRoundRect(x, y, x2, y2);
delay(2000);
// Draw some random filled circles
x=27+random(746);
y=41+random(397);
myGLCD.fillCircle(x, y, 25);
delay(2000);
// Draw some lines in a pattern
myGLCD.setColor (255,0,0);
for (int i=15; i<463; i+=5)
myGLCD.drawLine(1, i, (i*1.66)-10, 463);
for (int i=463; i>15; i-=5)
myGLCD.drawLine(798, i, (i*1.66)+30, 15);
myGLCD.setColor (0,255,255);
myGLCD.drawLine(1, i, 770-(i*1.66), 15);
myGLCD.drawLine(798, i, 810-(i*1.66), 463);
delay(2000);
// Draw some random circles
for (int i=0; i<250; i++)
x=32+random(736);
y=45+random(386);
r=random(30);
myGLCD.drawCircle(x, y, r);
delay(2000);
// Draw some random rectangles
x=2+random(796);
y=16+random(447);
x2=2+random(796);
y2=16+random(447);
myGLCD.drawRect(x, y, x2, y2);
delay(2000);
// Draw some random rounded rectangles
x=2+random(796);
y=16+random(447);
x2=2+random(796);
y2=16+random(447);
myGLCD.drawRoundRect(x, y, x2, y2);
delay(2000);
x=2+random(796);
y=16+random(447);
x2=2+random(796);
y2=16+random(447);
myGLCD.drawLine(x, y, x2, y2);
delay(2000);
for (int i=0; i<10000; i++)
myGLCD.drawPixel(2+random(796), 16+random(447));
delay(2000);
myGLCD.fillScr(0, 0, 255);
myGLCD.fillRoundRect(320, 190, 479, 289);
myGLCD.print("That's it!", CENTER, 213);
myGLCD.print("Restarting in a", CENTER, 239);
myGLCD.print("few seconds...", CENTER, 252);
myGLCD.setColor(0, 255, 0);
myGLCD.setBackColor(0, 0, 255);
myGLCD.print("Runtime: (msecs)", CENTER, 450);
myGLCD.printNumI(millis(), CENTER, 465);
delay (10000);
When talking to chatgtp It says that this screen only uses 3.3v logic levels. Is the title just wrong and its not intended for 5v logic or is Chatgtp throwing me down a rabbit hole?
Teensy uses 3.3v so if that's the case ill just sit around and wait for the board.
Just trying to make sure i don't have a toasted display out of the box.
