Cheapest modem that works with ESP8266 wifi
I'm trying to get one of the wifi examples to work and I'm getting a message that says "doesn't connect". I'm not sure about the password or the port because I have an old Dlink DIR-615 and can't find where to set the password or the port. I guess I need to buy something that works or update the firmware. Is there anything else I can do? I have other ESP8266 chips. Maybe I could configure one as a server? Another question: in the code where they have 'host', what is that? I put the ip address of the modem.
    This sketch establishes a TCP connection to a "quote of the day" service.
    It sends a "hello" message, and then prints received data.
#include <ESP8266WiFi.h>
#ifndef STASSID
#define STASSID "my ssid"
#define STAPSK "my password"
#endif
const char* ssid = STASSID;
const char* password = STAPSK;
const char* host = "192.168.88.2";
const uint16_t port = 17;
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  /* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
     would try to act as both a client and an access-point and could cause
     network-issues with your other WiFi-devices on your WiFi-network. */
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  static bool wait = false;
  Serial.print("connecting to ");
  Serial.print(host);
  Serial.print(':');
  Serial.println(port);
  // Use WiFiClient class to create TCP connections
  WiFiClient client;
  if (!client.connect(host, port)) {
    Serial.println("connection failed");
    delay(5000);
    return;
  // This will send a string to the server
  Serial.println("sending data to server");
  if (client.connected()) { client.println("hello from ESP8266"); }
  // wait for data to be available
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 5000) {
      Serial.println(">>> Client Timeout !");
      client.stop();
      delay(60000);
      return;
  // Read all the lines of the reply from server and print them to Serial
  Serial.println("receiving from remote server");
  // not testing 'client.connected()' since we do not need to send data here
  while (client.available()) {
    char ch = static_cast<char>(client.read());
    Serial.print(ch);
  // Close the connection
  Serial.println("closing connection");
  client.stop();
  if (wait) {
    delay(300000);  // execute once every 5 minutes, don't flood remote service
  wait = true;
"quote of the day" service supposed to be your host.
Your wifi credentials you put here on these two lines:
May I suggest good tutorials for Esp8266:
Can you connect or see the DLink from your Phone.
Yeah, I can get internet fine.
My goal is to modify it to be "this day in history"
