Check for a part of a filename / searching files with certain name in a path
Hi
Assuming I read a directory of a SD card I get a list of filenames in return, which are of type char.
Among these are files named what12.txt, what234.txt, what2.txt and so on.
Now how can I do a simple
"look for files with a certain name" THEN "pick the one with the highest ID?
While this is such a simple task in almost ANY language it makes me fail totally at c++.
For obvious reasons (simulator) a testcode without SD reading:
#include <SoftwareSerial.h>
char buffer[]="what12.txt";
char returnChar[4];
char * ptr = strchr(buffer, 'w');
strncpy(returnChar, ptr, 4);
 Serial.println(returnChar);
 // of course NOT working as I assume a string here :-(
 if (returnChar=="what") {
    Serial.println(" hit -what-");
I know I can convert the ID int with atoi() for the math for the highest id but
how can I do the comparison for "what" ?
You can't use == to compare char arrays. Use strcmp()
You use the strcmp() function, but only after you have correctly terminated the target string with a '\0'
Don't forget that a string containing "what" needs an array of 5 elements so that the '\0' can be used as its terminator
strstr might be of help.
see strstr() will find the "what" in what12.txt
Bob is correct (see this page). So you will need to increase the size of your array, to hold that null-terminator:
char returnChar[5];
Yes, handling and manipulating text is not as easy in C/C++ as in many other languages. But those languages won't run on most Arduino, because they require far more resources (memory & processing speed) than most Arduino have.
Some more modern and advanced Arduino boards, with more resources, can run Micro-Python or Circuit-Python or similar. You would find that, if you wrote the nearest equivalent code in C/C++ and in Python (each code written by a coder competent in that language) the C/C++ code would probably run 10+ times faster and use 10 times fewer resources, compared to Python. That's why C/C++ was chosen as the original Arduino language.
You can make use of the String library in C/C++, which makes this kind of thing as easy as it is in most other languages. But that library requires more resources and can be a problem on basic Arduino boards (unless you are careful and you know what pitfalls to avoid).
thanks guys, this works:
 if (strstr(returnChar,'what')) {
I guess strcmp too but looks more complicated to me. Advantage/disadvantage?
Both functions are not in the arduino reference?
strcmp() is a simpler function than strstr().
But the advantage of strstr() is that you would not have to use strncpy() first to take the first 4 characters out of the file name. You can use strstr() directly on the filename, which you don't seem to be doing in post #8.
Oh, are you sure? That looks wrong to me. Wrong type of quote marks. ' is for single characters (char). " is for strings/char arrays.
Well, it did in a browser simulator , might give trouble on the real device then.
EDIT:yes, you are right, ' ' gives an error in IDE
You're making life complicated; you have found "what" but you haven't gotten the numbers following that.
Simple demo to print everything following "what" (not tested).
char *ptr = strstr(someName, "what");
if (ptr != nullptr)
  ptr+=strlen("what");
  Serial.println(ptr);
yes so true ! plus:
Serial.println(atoi(ptr));
and I got the number
maybe c++ isn't so bad at all at the end :wink:
thanks!
Does your code so what you described, ie
I'm surprised that that works, but it is not correct. Use double quotes for C-strings, as follows.
if (strstr(returnChar,"what")) {
as in the follow up comments, it only works in the simulator, check for yourself:
Then the simulator is wrong, as well as the code.
indeed
