When the button is pressed, the LED lights up for 30 seconds. If the button is not pressed during the 30 seconds, the LED turns off until the button is pressed again. If during that 30 seconds the button is pressed, the LED will remain on for another 30 seconds. Any idea of the code for this?
I thought about using delay but am pretty sure I need a while loop with some sort of time delay. Unsure.
A while loop will have the same effect as delay(), it will block your code, so it won't respond to button presses unless you setup an interrupt for your button.
But you should look at the Blink Without Delay example for a better, non blocking method
start of loop()
if millis() - start time >= 30 seconds and timing == true
turn off LED
timing = false
end if
if button becomes pressed
turn on LED
save start time from millis()
timing = true
end if
end of loop()
