Check for the same value and apply setting! Search in SD card
Hello, in one of my works I extract weather forecast data from Yahoo. In their documentation (https://developer.yahoo.com/weather/documentation.html) it is defined a code to every weather conditions.. After I extract this code, instead of the description, I wrote a txt file in the sd card with the code and respective description, like:
[0=tornado] --> [settingname=settingvalue]
I wrote a function to read from sd card, each one of this names and values to other things in the program:
// Função de Leitura dos dados no Cartão SD
void readSD(File fileName, char* fileTXT) {
  char character;
  String settingName;
  String settingValue;
  fileName = SD.open(fileTXT);
  if (fileName) {
    while (fileName.available()) {
      character = fileName.read();
      while ((fileName.available()) && (character != '[')) {
      while ((fileName.available()) && (character != '=')) {
        settingName = settingName + character;
      while ((fileName.available()) && (character != ']')) {
        settingValue = settingValue + character;
      if (character == ']') {
        // Apply the value to the parameter
        applySetting(settingName, settingValue);
        // Reset Strings
        settingName = "";
        settingValue = "";
    // close the file:
    fileName.close();
    // if the file didn't open, print an error:
    Serial.println("error opening .txt");
[\code]
But now, I want a function to compare the code extracted from yahoo with the ones in the sd card, and after that, apply the description, p.e, if code = 0, it will search in the txt for that settingname, applying the description after that.
Thanks, António
Did you have a question?
SORRY!! I must have deleted, after I edited the post! I want to compare the received weather code, with the ones wrote in the sd card, and apply the corresponding description!
