Hello, I want to make a library which supports both Arduino and standard C++. when i use g++ compiler I can use this piece of code to detect OS that the library is compiled on:
#ifdef __Liunx
//this code only get compiled in Linux
#endif
now is there any equivalent to this?
Regards.
Sorry for my bad English.
Welcome to the forum
What makes you think that the Arduino does not use standard C++ ?
well it does not use stl libraries...
Hi @Master_81 . Even though it is not guaranteed by the build system, nor even documented anywhere, it is a common convention for Arduino boards platforms to define a global macro named ARDUINO
For example, here you can see that -DARDUINO
flag in the command template used by the "Arduino AVR Boards" platform to compile C++ files (which includes the .ino
files of the sketch):
compiler.objcopy.eep.extra_flags=
compiler.elf2hex.extra_flags=
# AVR compile patterns
## Compile c files
recipe.c.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.c.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.c.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Compile c++ files
recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpp.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Compile S files
recipe.S.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.S.flags} -mmcu={build.mcu} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} {compiler.S.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Create archives
# archive_file_path is needed for backwards compatibility with IDE 1.6.5 or older, IDE 1.6.6 or newer overrides this value
archive_file_path={build.path}/{archive_file}
recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}"
## Combine gc-sections, archives, and objects
Then don't use them in your code
Thank you for answering...
does ARDUINO
macro work with esp32/esp8266 boards?
It does:
recipe.hooks.prebuild.5.pattern=bash -c "[ ! -f "{build.source.path}"/build_opt.h ] || cp -f "{build.source.path}"/build_opt.h "{build.path}"/build_opt.h"
recipe.hooks.prebuild.6.pattern=bash -c "[ -f "{build.path}"/build_opt.h ] || touch "{build.path}"/build_opt.h"
recipe.hooks.prebuild.5.pattern.windows=cmd /c if exist "{build.source.path}\build_opt.h" COPY /y "{build.source.path}\build_opt.h" "{build.path}\build_opt.h"
recipe.hooks.prebuild.6.pattern.windows=cmd /c if not exist "{build.path}\build_opt.h" type nul > "{build.path}\build_opt.h"
## Compile c files
recipe.c.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.cpreprocessor.flags} {compiler.c.flags} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" -DARDUINO_VARIANT="{build.variant}" -DARDUINO_PARTITION_{build.partitions} {compiler.c.extra_flags} {build.extra_flags} "@{build.opt.path}" {includes} "{source_file}" -o "{object_file}"
recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpreprocessor.flags} {compiler.cpp.flags} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" -DARDUINO_VARIANT="{build.variant}" -DARDUINO_PARTITION_{build.partitions} {compiler.cpp.extra_flags} {build.extra_flags} "@{build.opt.path}" {includes} "{source_file}" -o "{object_file}"
## Compile S files
recipe.S.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.cpreprocessor.flags} {compiler.S.flags} -DF_CPU={build.f_cpu} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" -DARDUINO_VARIANT="{build.variant}" -DARDUINO_PARTITION_{build.partitions} {compiler.S.extra_flags} {build.extra_flags} "@{build.opt.path}" {includes} "{source_file}" -o "{object_file}"
## Create archives
recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" "-Wl,--Map={build.path}/{build.project_name}.map" "-L{compiler.sdk.path}/lib" "-L{compiler.sdk.path}/ld" "-L{compiler.sdk.path}/{build.memory_type}" {compiler.c.elf.flags} {compiler.c.elf.extra_flags} {build.extra_flags} -Wl,--start-group {object_files} "{archive_file_path}" {build.extra_libs} {compiler.c.elf.libs} {compiler.libraries.ldflags} -Wl,--end-group -Wl,-EL -o "{build.path}/{build.project_name}.elf"
## Build the app.ld linker file
recipe.hooks.linking.prelink.1.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.mkdir}" -p "{build.path}/ld_h/"
recipe.hooks.linking.prelink.2.pattern="{runtime.tools.python3.path}/python3" -I "{runtime.tools.cp}" "{runtime.platform.path}/tools/sdk/ld/{build.flash_ld}" "{build.path}/ld_h/local.eagle.flash.ld.h"
recipe.hooks.linking.prelink.3.pattern="{compiler.path}{compiler.c.cmd}" -CC -E -P {build.vtable_flags} {build.mmuflags} "{build.path}/ld_h/local.eagle.flash.ld.h" -o "{build.path}/local.eagle.flash.ld"
recipe.hooks.linking.prelink.4.pattern="{compiler.path}{compiler.c.cmd}" -CC -E -P {build.vtable_flags} {build.mmuflags} "{runtime.platform.path}/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "{build.path}/local.eagle.app.v6.common.ld"
## Compile c files
recipe.c.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.cpreprocessor.flags} {compiler.c.flags} -D{build.sdk}=1 -DF_CPU={build.f_cpu} {build.lwip_flags} {build.debug_port} {build.debug_level} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" {build.led} {build.flash_flags} {compiler.c.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
recipe.cpp.o.pattern="{compiler.path}{compiler.cpp.cmd}" {compiler.cpreprocessor.flags} {compiler.cpp.flags} -D{build.sdk}=1 -DF_CPU={build.f_cpu} {build.lwip_flags} {build.debug_port} {build.debug_level} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" {build.led} {build.flash_flags} {compiler.cpp.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Compile S files
recipe.S.o.pattern="{compiler.path}{compiler.c.cmd}" {compiler.cpreprocessor.flags} {compiler.S.flags} -D{build.sdk}=1 -DF_CPU={build.f_cpu} {build.lwip_flags} {build.debug_port} {build.debug_level} -DARDUINO={runtime.ide.version} -DARDUINO_{build.board} -DARDUINO_ARCH_{build.arch} -DARDUINO_BOARD="{build.board}" {build.led} {build.flash_flags} {compiler.S.extra_flags} {build.extra_flags} {includes} "{source_file}" -o "{object_file}"
## Create archives
recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {build.exception_flags} -Wl,-Map "-Wl,{build.path}/{build.project_name}.map" {compiler.c.elf.flags} {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" -Wl,--start-group {object_files} "{archive_file_path}" {compiler.c.elf.libs} -Wl,--end-group "-L{build.path}"
It also works with all the official Arduino boards platforms (AVR, megaAVR, SAMD, SAM, Mbed OS)
system
Closed
March 11, 2023, 1:24pm
9
