I'm new to arduino. I connected a motor driver (ULN2003) to a 5V Stepper Motor.
I used the sample code from the Arduino program and it worked perfectly fine this morning (Motor and driver was lighting up)
Now I tried reconnecting everything to the way it was this morning to retest the motor and nothing was lighting up and the motor was not moving at all.
Is there a way to troubleshoot a driver motor? I troubleshooted the stepper motor by inserting a led to the connections of the motor to see if the led glowed.
In the end, I believe that the stepper motor is still functional, and something is wrong with motor driver.
What I'm thinking is.... the motor driver is NOT meant to get its power supply from the Arduino.
Using the arduino's supply to power a motor is like trying to start up a car motor with an 'AA' battery.
Maybe if your motor uses relatively low amount of power, then your circuit might still work. But probably better off supplying your ULN2003 from a supply that is not from your Arduino.
The 5v output from an Arduino cannot provide enough current to drive a motor. If you try to draw too much current the 5v will fall and cause the Arduino to behave erratically. And you may overload and damage the Arduino's voltage regulator.
