Check if the communication of the sensor work
Hi guys,
I'm using this sensor: DHT22, MPL11A2, DS18B20 and SD shield.
I would like to check, in the setup, if the communication from arduino to the sensors work. For now I'm using this code:
    //SD Shield
    if (!SD.begin(4)) {
        Serial.println("Modulo SD: ERRORE");
        return;
    Serial.println("Modulo SD: OK");
    //DHT22
    if (isnan(dht.readTemperature()) || isnan(dht.readHumidity())) {
        Serial.println("Modulo DHT: ERRORE");
    else {
        Serial.println("Modulo DHT: OK");
    //DS18B20
    ds18b20.requestTemperatures();
    if (isnan(ds18b20.getTempCByIndex(0)) || isnan(ds18b20.getTempCByIndex(0))) {
        Serial.println("Modulo DS18B20: ERRORE");
    else {
        Serial.println("Modulo DS18B20: OK");
    //MPL115A2
    if (isnan(mpl115a2.getPressure())) {
        Serial.println("Modulo MPL115A2: ERRORE");
    else {
        Serial.println("Modulo MPL115A2: OK");
So, there is a better way ?
Thank you
What values do you get back when a device is not there? I assume isnan() tests for Not a Number but a simple compare may be simpler.
Rob
for the arduino work ! lool
for example, if I remove ds18b20 the serial communication read -127.00°C. This is a number and for the sketch there is a communication.
But I need a confirm that the sensor communicate correctly with arduino !
if I remove ds18b20 the serial communication read -127.00°C. This is a number...
So your current code doesn't work then?
I thought it did work but you just wanted a better way.
Rob
