I want to be able to turn on the lights between timeOn and TimeOff. The issue is that I have is that it example have to work if timeOn is 1500 and timeOff is 1800. And if timeOn is 1500 and timeOff is 0700. ( The crossing of midnight make it harder for me to use if timeOn is less time && time is more than timeOff. )
Im using Timelib, and time input from Blynk. With Timelibs I have the opportunity to get time in various different ways, including the same way I get it from Blynk, which is seconds since 00:00
BulldogLowell:
I wrote a library to do exactly what you are looking to do
Having some issues using it.
Not sure if its because I already have an RTC clock ?
Isolated what I use is:
void ledOn() {
for(int i=0;i<NUM_LEDS;i++){
leds[i] = CHSV( hueDay, satDay, briDay);
FastLED.show();
void ledOff() {
leds[i] = CHSV( hueNight, satNight, briNight);
FastLED.show();
DailyTimer ledTimer1(
true, // AutoSync true or false, will run the startTimeCallback() if restarts within the active range or after range changes and you are in the range
inputStart, // Start Hour
inputStartminutes, // Start Minute
inputStop, // End Hour
inputStopminutes, // End Minute
EVERY_DAY, // SUNDAYS, MONDAYS, TUESDAYS, WEDNESDAYS, THURSDAYS, FRIDAYS, SATURDAYS, WEEKENDS, WEEKDAYS, or EVERY_DAY
FIXED, // OPTIONAL - FIXED, RANDOM, RANDOM_START, or RANDOM_END
ledOn, // pointer to function to execute at Start time, or a Lambda as in this example:
ledOff // pointer to function to execute at End time
ledTimer1.begin();
void dailylibtimer() {
static unsigned long lastTime = 0;
DailyTimer::update();
if(millis() - lastTime >= 1000)
char timeBuffer[32] = "";
sprintf(timeBuffer, "Time:%2d:%02d:%02d\tDate:%02d/%02d/%4d", hour(), minute(), second(), month(), day(), year());
Serial.println(timeBuffer);
lastTime = millis();
dailylibtimer();
jremington:
No, that statement is fine, especially if you use unix time instead of day times.
YOU have to deal with the special cases, which would obviously require a different, but also simple comparison.
I understand that, I just can't grasp the logic I should use.
Maybe I found out how.
If inputstop > inputstart ( // inputstart and inputstop doesn't cross midnight
If time > timestart && time < timestop (
Ledon
If input stop < inputstart ( // crosses midnight
If time > inputstart && time > inputstop (
Ledon
If time < inputstart && time < inputstop (
Ledon
Else (ledoff)
Using Unix time (seconds since 00:00:00 Jan 1, 1970 UTC), the single statement I posted works for every possible case, spanning any number of seconds, minutes, hours, days, weeks, months or years between 1970 and 2038.
jremington:
Hmm, only if you enter and spesific time and date ? Example Monday 1.1.2010 13:00 (1262350800) to Tuesday 2.1.2010 07:00 (1262415600) ?
In my case I only have two time inputs, which is just 13:00 and 07:00
