Check my code plz?
hi. everytime i try to compile this in arduino IDE the programe crashes.
can someone help? <www.mitchellpage.com.au/wireless1.zip
//PROCESSING TO WIRING VERSION 4
char val;             // variable to receive data from the serial port
int led = 0;          // variable that keeps which led must be turn on next
int ledpinFour = 2;
int ledpinFive = 3;
int ledpinFour = 4;
int ledpinFive = 6;
int ledpinFour = 5;
int ledpinFive = 6;
int ledpinSix = 7;
int ledpinSeven = 8;
int ledpinEight = 9;
int ledpinNine = 10;
int viz2_state = 0;
int viz3_state = 0;
int vizOneActive;
int vizTwoActive;
int vizThreeActive;
pinMode(ledpinOne, OUTPUT);
  pinMode(ledpinTwo, OUTPUT);
  pinMode(ledpinThree, OUTPUT);
  pinMode(ledpinFour, OUTPUT);
  pinMode(ledpinFive, OUTPUT);
  pinMode(ledpinSix, OUTPUT);
  pinMode(ledpinSeven, OUTPUT);
  pinMode(ledpinEight, OUTPUT);
  pinMode(ledpinNine, OUTPUT);
  beginSerial(9600);       // start serial communication at 9600bps
  if ( serialAvailable() > 0)       // if data is available to read
    val = serialRead();        // read it and store it in 'val'
  analogWrite(0, val);
  //CHECK WHICH VALUE IS SENT
  if( val == 'A' ){           //turn viz 1 on
    vizOneActive = 1;
  if ( val == 'B' ){          //turn viz 2 on
    vizTwoActive = 1;
  if ( val == 'C'){           //turn viz 3 on
    vizThreeActive = 1;
  if( val == 'D' ){           //turn viz 1 off
    vizOneActive = 0;
  if ( val == 'E' ){          //turn viz 2 off
    vizTwoActive = 0;
  if ( val == 'F'){           //turn viz 3 off
    vizThreeActive = 0;
  if ( val == 'G'){           //turn all vizualizations off
    vizOneActive = 0;
    vizTwoActive = 0;
    vizThreeActive = 0;
    turn_all_off();
  //IF STATES ARE ON
  if (vizOneActive == 1){
    ledVizOne();
  if (vizTwoActive == 1){
    ledVizTwo();
  if (vizThreeActive == 1){
    ledVizThree();
  //IF STATES ARE OFF
  if (vizOneActive == 0){
    turn_vizOne_off();
  if (vizTwoActive == 0){
    turn_vizTwo_off();
  if (vizThreeActive == 0){
    turn_vizThree_off();
  delay(200);
 VISUALIZATION FUNCTIONS
//VISUALIZATION 1
//function to continually turning on and off led's in cycle
void ledVizOne(){
  turn_vizOne_off();
  digitalWrite(led, HIGH);
  led = (led + 1) % 3;
//VISUALIZATION 2
//function to turn all led's off in blinking fashion
void ledVizTwo(){
  if (viz2_state == 0) {
    turn_vizTwo_on();
    viz2_state = 1;
  else {
    turn_vizTwo_off();
    viz2_state = 0;
//VISUALIZATION 3
//function to turn leds off/on from outside in
void ledVizThree() {
  if (viz3_state == 0) {
    digitalWrite(ledpinSeven, HIGH);
    digitalWrite(ledpinNine, HIGH);
    digitalWrite(ledpinEight, LOW);
    viz3_state = 1;
  else {
    digitalWrite(ledpinSeven, LOW);
    digitalWrite(ledpinNine, LOW);
    digitalWrite(ledpinEight, HIGH);
    viz3_state = 0;
 OTHER FUNCTIONS
//function to turn OFF all the lights connected to digital pins 0 to 2
void turn_vizOne_off()
  int i;
  for(i=0; i<3; i++)
    digitalWrite(i, LOW);
//function to turn OFF all the lights connected to digital pins 8 to 10
void turn_vizTwo_off()
  int i;
  for(i=8; i<11; i++)
// function to turn ON all the lights connected to digital pins 8 to 10
void turn_vizTwo_on()
  int i;
  for(i=8; i<11; i++)
    digitalWrite(i, HIGH);
//function to turn OFF all the lights connected to digital pins 16 to 18
void turn_vizThree_off()
  int i;
  for(i=16; i<19; i++)
//function to turn OFF all the lights connected to digital pins 0 to 18
void turn_all_off()
  int i;
  for(i=0; i<19; i++)
sorry i can’t cut and past your code to test.
in the source code of the html page, it’s not in utf8, all with uggly “);”
a link to download ?
and what is suppose to do (to save some minutes to understand your code)
regards
eric
Sorry, didnt realise.
i have attached a link to download the .pde file. <www.mitchellpage.com.au/wireless1.zip
basically, this i have 9 LEDs aranged in clusters of 3. each cluster performs a seperate visualization (series of on/off blinking).
i have 3 pairs of on/off buttons in processing. basically i install the code onto arduino and run when connected to my computer, i should be able to turn the clusters (visualizationOne, visualizationTwo and visualizationThree) on and off by pressing buttons in processing which send commands (A,B,C …etc) to arduino
Please help. Thanks!
i have had a similar programming working with Wiring but i have made the jump to arduino - but its not working for me!
The first problem is that you’re declaring variables twice:
int ledpinFour = 2;
int ledpinFive = 3;
int ledpinFour = 4;
int ledpinFive = 6;
int ledpinFour = 5;
int ledpinFive = 6;
You can only have one called “ledpinFour” or “ledpinFive”.
The error “conflicting types for ledVizOne” is because you need a function prototype at the top of your code. (This won’t be necessary in Arduino 0004). That is, you’ll need something like this:
void ledVizOne();
for each of your functions.
Hey thanks Man :smiley:
Code compiles now!!!
Cheers!
