Check schematic for errors
I need help Checking my Schematic for errors image here:
Can you upload a picture with a higher resolution ?
That is the same picture, but upscaled :grimacing:
It is hard to check everything, but so far I see no problem.
There seems to be a resistor for the fingerprint scanner somehow. I don't understand that.
There is also a resistor in the SPI bus to the SD module. If the module is compatible with a 5V system, then that resistor should not be needed.
How are you going to power it ?
If you apply 12V to the DC barrel jack, then the voltage regulator on the Mega board gets too hot.
Well I am using circuito.io, and it should fix any errors by itself and there is a extra wall adapter power supply that is below the usb.
What is the voltage of wall adapter ?
The voltage is 12V. It is type 12VDC 2A.
I see a wiring diagram made from pictures but no schematic.
Check this link: How to make a schematic you can post.
I moved your topic to an appropriate forum category @direha.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
With 12V, the voltage regulator on the Mega board gets too hot.
