Hello,
I'm currently building a project that checks a certain DC/DC Converter using Arduino Mega 2560.
That includes, voltage measurments in the input and output, and checking short among the converter's pins, since the converter has numerous input pins for each polarity (I will call those IN+ and IN-) and output pins also for each polarity (OUT+ and OUT-). Also there are some pins in the converter that are responsible for turning on/off the following:
• The converter itself
• The protection (Reverse polarity input, over voltage, etc.)
• Frequency synchronization
And I need the Arduino to check if the correct pins are short (All IN+ pins are short, same for, IN-, OUT+ and OUT-)
I have no idea how can I check short between two or more pins other than with a fluke, which I already did, but the point in the project that the Arduino itself will be able to detect short.
Unfortunately I don't know the converter's circuit, moreover, the device itself looks extremely complicated. I cannot put the datasheet here for some reasons.....
Help would be appreciated!
Yes, I am building a test rig for the converter before I actually use it in real life, I only measure input and output voltage and trying to check short among the same pins.
This makes no sense to me. Your are writing about shorts. Short circuit between which pins?
Do You want to check that all IN+ have connections, all IN-.....etc.?
Okey. No checking for shorts between IN- and UT-, IN+ and UT+, IN- and UT+ and between IN+ and UT-.....
And the circuit is not powered during the test?
You didn't reply to my first line...., only the second.
I will say You have no reasonable choice. I suggest doing the test with a single circuit being only connected to the test rigg.
Else the project gets very complicated, likely unrealistic or maybe impossible.
