Check to see if valid web server GET request?
I have this partially, working; however, it breaks the download from happening with “Page Not Found.”
Here I have it commented out to allow downloads to work.
/*         // pageNotFound 404
         if (!( StrContains(HTTP_req, "GET / ")) || ( StrContains(HTTP_req, "GET /log.txt "))){
         // send a standard http response header
              client.println("HTTP/1.1 404");
              client.println("Content-Type: text/html");
              client.println("Connnection: close");
              client.println();
              // output webpage
              client.println("<!DOCTYPE HTML>");
              client.println("<html>\r\n");
              client.println("<h2>Page Not Found</h2>
         // reset buffer index and all buffer elements to 0
              req_index = 0;
              StrClear(HTTP_req, REQ_BUF_SZ);
I am expecting “Page Not Found” for any invalid request; this part is working.
What is missing or wrong?
Complete code attached to topic:.
Topic_CC3000_Weather_Observations_Webserver.zip (6.66 KB)
Did you mean to have one negative and one positive clause in your if statement? Perhaps you're missing a set of parens?
I am trying to negate, two clauses that are sperated by OR. Is the syntax correct to accomplish this task?
This is for a web server to check for invaild GET requests. Anything other than (StrContains(HTTP_req, "GET / ")) || (StrContains(HTTP_req, "GET /log.txt ")) will result in a "Page Not Found" exception.
Is there a better way to go about coding this task?
In my opinion, yes.
if(StrContains(HTTP_req, "GET / "))
   // Return the base page
else if(StrContains(HTTP_req, "GET /log.txt"))
   // Return the log file
   // Return the error page
Deal with the valid requests, first. Then, anything that’s left is an invalid request.
Thank you PaulS.
I have it working now. Here is what worked; had to add the additional code here…
else if ((!StrContains(HTTP_req, "GET / "))||(!StrContains(HTTP_req, "GET /log.txt"))){
Appreciate the reply .
William
CC3000_Weather_Observations_Webserver.zip (6.5 KB)
