I want to make a project with Arduino ATmega to check PTT based radio hand set Automatically. I want to check Mic , Speaker and PTT ..please guide me
Does not really sound like an Arduino project.
To check a radio hand set is operating correctly you would normally use a spectrum analyser.
A PC with a cheap SDR on it could carry out basic checks.
Sir ,just i want to check Mic and speaker serviceability only ...
In your first post you said you wanted to check PTT which is push to transmit.
That rather imples you want to check if the radio is actually transmitting.
Hello
post the block diagram and used hardware of your project.
Please guide me how can i check serviceability of mic, speaker and PTT switching with the help of Arduino
Where I can see the radio to be tested?
Test results will show on display,
ok, that is magic, I like it.
Where I can buy it ?
Did you mean headset?
A headset is headphones + microphone usually, a handset could mean the whole radio.
One way to test mic and speaker(s) simultaneously would be to use a small amp
between them (though this would cause feedback/howlround if not headphones).
