Checksum, EEPROM
Greetings,
My goal is to have a checksum created for flash memory, store the checksum in EEPROM, and compare the two.
I am using AVRDude to write the checksum value a420 to EEPROM
avrdude: Device signature = 0x1e950f
avrdude> write eeprom 0 0xa4
write eeprom 0 0xa4
avrdude> write eeprom 1 0x20
write eeprom 1 0x20
avrdude> quit
I found example code for calculating the checksum. The code converts the checksum to a string (a420), and reads the values out of EEPROM location 0 and 1, and converts to a string (a420). When the compare occurs, the results indicate they are not equal, I display the value of the checksum (str_Temp4) = a420.
For debug purposes, I change that to display the string created from reading EEPROM 0, 1, and display that value (str1) = a420.
The displayed values are equal, I don't understand why it doesn't pass.
The code:
  max_1.begin(MAX31865_3WIRE);  // set to 3WIRE  //Start probe 1
  max_2.begin(MAX31865_3WIRE);  // set to 3WIRE  //Start probe 2
  /* --- Initialize display -------------------------------------------------- */
  display.begin(SSD1306_SWITCHCAPVCC);
  display.clearDisplay(); //clear display buffer
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(35, 25);
  display.setFont(&FreeSansBold9pt7b);
  display.print(""); //write to display buffer
  display.display(); // diplay contents of display buffer
  // init done
  pixeltest(); //functional test all pixels of display
  delay(2000);
  display.clearDisplay(); //clear contents of display buffer
  // Checksum routine //
  lng_Checksum = 0;
  int_Checksum = 0;
  for (i = 0; i < 0x3FFF; i++)
    b = pgm_read_byte_near(i);
    lng_Checksum += (uint32_t)b;
  int_Checksum = (uint16_t)(lng_Checksum & 0x0000FFFF);
  itoa (int_Checksum, str_Temp4, 16);
  a = EEPROM.read(0);
  z = EEPROM.read(1);
  itoa (a, str1, 16);
  itoa (z, str2, 16);
  strcat(str1, str2);
  /******************compare checksum to EEPROM*******************/
  if (str_Temp4 != str1)
    while (str_Temp4 != str1) {
      display.setCursor(35, 25);//(30, 25) //sets base of character string
      display.setFont(&FreeSansBold9pt7b); //defines Font being used
      //display.print(" Ck Err"); //laod display buffer
      //display.print(str1); //laod display buffer
      display.print(str_Temp4);
      display.display(); //display above message
    display.setCursor(30, 25);//(30, 25) //sets base of character string
    display.println("V1"); //laod display buffer
    delay(2000);
    display.println("  PASS"); //laod display buffer
    delay(2000);
I would just compare the two integer checksums, and save a whole lot of trouble.
If these are char arrays, you can't use != and ==, you need to use strcmp() for those.
@jremington - thank you for the quick reply. int_Checksum is displayed = 44174
To write that to EEPROM I would need to covert 44174 to hex? And when I read it back out, I don't know how to read the variables a and z and combing them without making them a string.
How would I accomplish that?
No. Just store the two bytes in the correct order, or use the EEPROM_writeAnything routine to store the int.
HEX is a human readable representation of a binary number, similar to decimal representation.
thanks to you both:
Cosme_Fulanito -
-If these are char arrays, you can't use != and ==, you need to use strcmp() for those.
Success in making the change to strcmp()
jremington -
Thank you for the direction:
-No. Just store the two bytes in the correct order, or use the EEPROM_writeAnything routine to store the int.
-HEX is a human readable representation of a binary number, similar to decimal representation.
I will look into using EEPROM_writeAnything routine as well.
jremington:
Is there any value in that? Current standard eeprom library has put and get methods that can read and write integers, structs etc
Yes.
