Hi all,
I do not really understand if the
is saying that an checksum is integrated.
How does update see the difference between ram and eeprom structure ?
can I use the checksum from update anywhere?
so will a write error be captured?
thanks Thomas
Hi all,
thanks Thomas
Which Arduino/MCU? Do you see something about checksum? It is open source, you can peek into the code.
If you have in mind ATmega which has real EEPROM, the update() method just compare a byte and overwrites it if it is different. Nothing more. Writing into EEPROM is different as writing into RAM. On C level it uses eeprom_write_byte(), resp. eeprom_update_byte() etc. On system level the EEPROM has separate address space and registers.
Hi
ok thanks.
so I need a own checksum write error handling?
I am using arduinos and ESP8266
concerning open source, I am not an expert to fully understand the code .....
Thanks t
For Arduinos, you write your own. There is an example how to calculate the crc. I calculate the crc over the eeprom minus the last 4 bytes and store the 4-byte crc in the last 4 bytes.
If I'm not mistaken, a posted an example. Search for my user name plus eeprom and you should be able to find it. Include crc if needed.
No idea about esp.
CRC is imported in AVR (part of Arduino SW), see ..\hardware\tools\avr\avr\include\util\crc16.h.
