Chemical resistant flow sensor?
I've been considering a project that would require pH correcting water with an acid by using a flow meter & solenoid valve to quantify the acid being added to a relative amount of water, but I am running into an issue finding a flow meter that would chemical resistant enough to work with the acid.
Any suggestions on where I might look for something like that?
What is Your education regarding chemistry?
pH balancing using acid, or the opposite, might not be easy. A few drops to much and the balance easily swings all over the scale.
What about using a peristaltic pump?
You may need industrial quality plumbing, valves and sensors, and they are expensive.
Omega is where I go, but there are many other suppliers.
jremington:
Yes, the fact I need one for 1/4 or 3/8 tubing & acid is where I am running into an issue.
One of the few places that look like they might be an option is JLC's Titan 800 series, they are just over $100 which is still fairly expensive...until I look at the other options
Low Cost PVDF Liquid Flow Meters | JLC International | jlcinternational.com
You are on the right track.
Thanks for the recommendation to look at Omega. Looks like a nice resource to be aware of.
It also depends a lot on which acid you use, and what concentration. Silicone tubes seem to have no problem with aquarium grade pH adjuster.
+1 for a peristaltic pump. The ones with brushed DC motor give a fairly reliable dose based simply on runtime; if you want high precision dosing use a stepper motor.
