I want to build a chess computer, like the kind that were popular in the late '70s. Something like this: http://www.boris-is-king.com/homepage.htm#110179313 . I have a few questions about the best approach.
The chess engine will run on a computer, like a Raspberry Pi or a BeagleBone Black. The chess engine will be a subprocess of a python program that will handle communication with the interface. The human interface will be 8 digits of Alphanumeric LED (like DL2416 or DL1414) and a matrix keypad.
I have built some i2c interfaces for the LED displays, using MCP23017 i/o expanders, and I imagine I could also read the keypad matrix using an i/o expander or an i2c keypad matrix decoder.
So here is the question that I'm thinking of. Should I use a microcontroller to interface with the i2c user interface elements (the LED displays and the keypad), and then interface the microcontroller with the computer? Or should I directly control the i2c bus from the computer? If I went with a microcontroller, I was thinking of using a uC with a usb interface to connect to the computer. Maybe something based on a ATMEGA32U4? Maybe a Teensy?
What are the tradeoffs I should consider. I thought maybe it would be easier for me to base the interface on interrupts is I used a microcontroller rather than i2c tools through the python program.
Thanks for any ideas or comments you may have.
Jimmy
