Hi All,
i'm pretty new to all of this. But with codes find in on this forum i was almost able to create a working code.
Project:
Lightsensor
5v DC motor
MKR wifi 1010
DHT22 sensor
All is working expect of the motor protocol.
This needs to be if its hits light higher then 200 door needs to open (motorUp)
light lower then 100 door closing (motordown)
only the motor only needs to turn 1 time event and not doing this every 5 a 10 seconds.
What is the best way of doing this?
here is my current code:
Download latest Blynk library here:
https://github.com/blynkkk/blynk-library/releases/latest
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Sketch generator: http://examples.blynk.cc
Blynk community: http://community.blynk.cc
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
This example code is in public domain.
This example shows how to use Arduino MKR 1010
to connect your project to Blynk.
Note: This requires WiFiNINA library
from http://librarymanager/all#WiFiNINA
Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <SPI.h>
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
#include <DHT.h>
//Constants
int photocellPin = A0;
int l = 0;
#define MotorDown 8
#define MotorUp 9
#define DHTPIN 6
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
bool light = true; // day (1) & Night (2) status
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "xxxxxxxxxxxx";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "xxxxxxxxx";
char pass[] = "xxxxxxxx";
void sendSensor()
l = analogRead(photocellPin);
Serial.print("Light = ");
Serial.println(l);
if (l > 200){
light = true;
Serial.println("status: Day");
Serial.println(light);
else if (l <100){
light = false;
Serial.println("status: Night");
delay(10000); // delay 10 sec between readings
float h = dht.readHumidity();
float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Debug console
pinMode(MotorDown, OUTPUT);
pinMode(MotorUp, OUTPUT);
sendSensor(); // Get a light reading and set status
Blynk.begin(auth, ssid, pass);
dht.begin();
// Setup a function to be called every 10 second
timer.setInterval(10000L, sendSensor);
void opendoor()
digitalWrite(MotorUp, HIGH);
digitalWrite(MotorDown, LOW);
delay(2500);
light = true;
Serial.println("door: open");
// stop motor loop
while (light == true){
digitalWrite(MotorUp, LOW);
Serial.println("Motor Stopped: Day");
void closedoor()
digitalWrite(MotorDown, HIGH);
delay(2500);
light = false;
Serial.println("door: Closed");
// stop motor loop
while (light == false){
Serial.println("Motor Stopped: Night");
if (light == 1){ // If the light status changes execute these
opendoor(); // Open
else if (light == 2);{
closedoor(); // Close
delay(5000);
Blynk.run();
timer.run();
Blockquote
